Star test looks good but.....
14 replies to this topic
#1 bill.beauchemin
bill.beauchemin
  • Loc: Paradise Ca.
Posted 20 May 2025 - 02:32 PM
My star test looks good but when I get close to focus they change to terrible looking. I can't really run auto-focus.
#2 gstrumol
gstrumol
  • Loc: north of Detroit, Michigan USA
Posted 20 May 2025 - 02:43 PM
Your collimation is off, as the central shadows aren't centered. Also, for a proper star test you should be using high magnification and looking to see if the central dot (Poisson point) is centered in the diffraction rings.
  • Jim Waters, havasman and VA3DSO like this
#3 bill.beauchemin
bill.beauchemin
  • Loc: Paradise Ca.
Posted 20 May 2025 - 02:48 PM
That's funny everyone else this was good. The center image is high mag. The corners are not.
#4 azure1961p
azure1961p
Posted 20 May 2025 - 02:55 PM
Astigmatism perhaps?
#5 JMP
JMP
Posted 20 May 2025 - 03:16 PM
In his classic article on collimation, Thierry Legault explains that looking at the defocused ring is only the first step toward dialing in collimation.
http://www.astrophoto.fr/collim.html
  • VA3DSO, Brain&Force, sevenofnine and 1 other like this
#6 bill.beauchemin
bill.beauchemin
  • Loc: Paradise Ca.
Posted 20 May 2025 - 06:55 PM
I was thinking doing the same as the article going to step two then three. Im using an RC8 and have as of yet seen those rings. I think its due to using a asi585mc not at unity gain I was using the same gain as my P1 cameras. Tonight im using my Ares-m mono with a L filter.
Edited by bill.beauchemin, 20 May 2025 - 07:01 PM.
#7 JMP
JMP
Posted 20 May 2025 - 07:49 PM
Try the mono cam with the red filter. There's a program called "metaguide" that can help you here.
https://smallstarspot.com/metaguide/
Edited by JMP, 20 May 2025 - 07:51 PM.
  • speedster likes this
#8 bill.beauchemin
bill.beauchemin
  • Loc: Paradise Ca.
Posted 20 May 2025 - 08:10 PM
I'll give it a try, thanks
#9 ChristianG
ChristianG
  • Loc: Ottawa, Canada
Posted 20 May 2025 - 08:44 PM
Gary is right. Look at best-focus diffraction pattern with eyepiece of focal length in mm equal to 1/2 the f-number of the telescope, or shorter. Use a bright star near zenith, or an artificial star in a long hallway. A bullseye indicate good cillimation. Good luck!
--Christian
#10 bill.beauchemin
bill.beauchemin
  • Loc: Paradise Ca.
Posted 20 May 2025 - 10:06 PM
I have 5 cameras one I wont use is the asi585mc. I have P1 Ares-m, poseidon-m, poseidon-c, uranus-m. Doesnt look like there compatible with metaguids requirements. Thanks for the tip.
#11 bill.beauchemin
bill.beauchemin
  • Loc: Paradise Ca.
Posted 21 May 2025 - 01:03 AM
Tried tonight to follow this but something is up. I could see the rings but I couldn't correct it.
I'm going back to breaking this ota down  on my bench and following a vid on my exact ota and the tools I have that match that vid.
#12 quilty
quilty
  • Loc: 52N8E
Posted 21 May 2025 - 03:23 AM
To me these pics are too far off focus to really tell
  • Eddgie and T1R2 like this
#13 azure1961p
azure1961p
Posted 22 May 2025 - 09:42 AM
An elongated primary like that is often present when a scope isn't cooled and the heat raising of the primary spears the circular appearance.
P.
  • Brain&Force likes this
#14 WadeH237
WadeH237
  • Loc: Ellensburg, WA
Posted 22 May 2025 - 09:59 AM
As a few have mentioned, your images are way too far out of focus to confirm your collimation is correct.  The size of the image is fine, but you want to get close enough to focus that the central donut is just starting to break out.
Regarding the comments that collimation is off due to the corner stars, it would be helpful to know which telescope you are using.  Off axis astigmatism is a characteristic of RC's, and they don't necessarily indicate any problem.  Once you have the central star correctly collimated, you can use the axis of astigmatism in the corners to adjust the primary mirror collimation.  You want to imagine lines running through the axes of astigmatism and adjust the primary so that they all intersect in the middle of the field.  Note that this must be done after the secondary is adjusted using a centered star.
And finally, you've told us that the in-focus stars look wrong, but an image of that would tell us more than the large donuts.
  • T1R2 and Brain&Force like this
#15 bill.beauchemin
bill.beauchemin
  • Loc: Paradise Ca.
Posted 24 May 2025 - 02:48 PM
I guess my collimation came out pretty good. This was taken without any reducer or flattener. Pixinsights Image Solver shows the focal length at 1620.32mm Guiding in phd2 was .16 px using a guide scope.
I was getting very frustrated getting this RC8 collimated. Using the tilt ring was the ticket. Also learning Sharpcap was a huge help. This is the first real image ive got from this ota. Oh the cam is a imx533
  • JMP, davidc135, Tyson M and 2 others like this
