Help finding replacement part for Orion XT8 Plus
Dob Orion
12 replies to this topic
#1 lbacker
lbacker
Posted 20 May 2025 - 04:21 PM
Good evening,
Orion XT8 plus. I need help finding and purchasing a now missing part, based on the manual, it’s either the Tensioning Knob or the alternate side knob for the right side. Simply, I only have one of these (shown in photo) and unable to locate the other to secure scope. Any ideas where to look or search? Thank you!
https://imgur.com/a/nwCY1yJ
  • sevenofnine likes this
#2 vtornado
vtornado
  • Loc: North East Illinois
Posted 20 May 2025 - 04:45 PM
I would take that part into an ACE or True Value hardware store and search their fastener cabnet for a bolt with the same diameter and pitch (It's probably metric maybe an M10).
If they have wing nuts in that size you could add a wing nut to the shaft to make it hand tightenable.   Any other large plastic or wood disk  can be used if you have a drill to drill a hole the correct size.    You can epoxy the disk to the bolt shaft.
  • ShaulaB and Jethro7 like this
#3 macdonjh
macdonjh
Posted 20 May 2025 - 05:04 PM
https://www.reidsupp...aded-knob-guide
  • scotsman328i likes this
#4 Jim45157
Jim45157
  • Loc: New Richmond, Ohio 45157
Posted 20 May 2025 - 06:41 PM
try scopestuff they should have what you need
  • Jethro7 likes this
#5 PIEJr
PIEJr
  • Loc: Northern Los Angeles County, Southern California
Posted 20 May 2025 - 07:05 PM
I would take the one you have to Lowe's or Home Depot and look through their drawers of parts.
Find the size and pitch of the threads.
If you find a fit, buy two and save the original for a spare. That way you'll have a match pair on your telescope.
Basically the same suggestion vtornado said.
  • scotsman328i and Jethro7 like this
#6 scotsman328i
scotsman328i
  • Loc: Charleston, SC.
Posted 20 May 2025 - 07:40 PM
Good evening,
Yeah man, Orion went mammary glands up last year. You’ll have to create a grip bolt and add a nylon washer to it to recreate the tension adjustment knob on the side. It wouldn’t be hard to do, everyone so far has given some great advice and I’d only echo what they’ve said. Ace Hardware, Lowe’s and Home Depot would have everything you need for a small project like this.
  • PIEJr likes this
#7 vtornado
vtornado
Posted 21 May 2025 - 08:40 AM
Ace and True Value have their fasteners in open bins.  My HD they are all in plastic bags.  You have to rip open the bags to try anything.   Sometimes you have to buy 2,3,4 .. instead of one.
#8 scotsman328i
scotsman328i
Posted 21 May 2025 - 08:46 AM
Haha, you’re right about that. Can’t tell you HOW MANY TIMES I’ve gone down to Lowe’s or HD and opened the drawers looking for bolts, screws or fasteners and see tons of empty plastic bags in the drawer with the contents of the bag strewn throughout the drawer also. lol.gif
#9 Tom Stock
Tom Stock
  • Loc: Saint Augustine, FL
Posted 21 May 2025 - 03:57 PM
10mm bolt (need to verify that), nylon washer and a 3d printer and you are good to go :)
#10 wavelandscott
wavelandscott
  • Loc: Ridgefield, Connecticut, USA
Posted 21 May 2025 - 05:25 PM
You might try giving High Point Scientific a ring…they bought the remains of Orion and may have some random bits and pieces laying around.  Might be worth a call before heading to the hardware store
#11 Yerman
Yerman
  • Loc: Ontario, Canada
Posted 22 May 2025 - 10:42 AM
Measure the diameter in millimeters of the threaded part. If you don’t have a vernier gauge just eye ball it with a metric ruler. You can’t go wrong it will be a whole number
Measure the length of the thread including the plastic washer. Go to your hardware store of choose and buy two Allen Head Cap Screws (AHCS) the diameter you measured x the length.
After that if you want to get fancy take appropriately sized plastic wheels from a toy car drill the axel hole slightly smaller than the Allen Head x the depth of the bolt head. Press the head of the bolt into the plastic wheel.
#12 RTLR 12
RTLR 12
  • Loc: Somewhere Northwest of Surprise Arizona
Posted 23 May 2025 - 12:15 PM
I bought all of these knobs at True Value Hardware. Take your sample with you.
Stan
#13 sevenofnine
sevenofnine
  • Loc: Santa Rosa, California 38*N., 122*W.
Posted 24 May 2025 - 03:39 PM
Welcome to C/N! flowerred.gif
I have the Orion XT8 Plus. What you have is the tensioning knob. The knob you're looking for is the same length with no washer or locknut. It is important to have the right plastic tube that inserts through the mount and into the scope or the altitude tension can not be adjusted properly. It sticks out of the mount 5mm. The tensioning knob has a shorter plastic tube but it fits flush with the melamine mount. The manual says to be sure to not get them mixed up or the tension system will not work. If you need more information, just send a PM. Good luck! borg.gif
Also tagged with one or more of these keywords: Dob, Orion
