New Plossl eyepiece not fitting Towa 114/900
20 replies to this topic
#1 bekfromoz
bekfromoz
Posted 20 May 2025 - 08:35 PM
Hi all
as posted the other day I have recently been given a classic Towa telescope (thanks to all who helped me identify it!).
Everything I'd read told me it uses a 1.25 inch eyepiece. I just bought one, a Plossl 10mm, and it's too big. Does anyone know what size eyepiece tube/holder the Towa actually has? Are eyepieces for it available to purchase or is there some sort of adapter I might be able to get? Or am I screwed? All I currently have for it is a 20mm and even with the Barwon x2 lens all I get is a large but pretty much 2D image of the moon.
bek
#2 jragsdale
jragsdale
  • Loc: Idaho
Posted 20 May 2025 - 08:40 PM
How much smaller is the eyepiece holder on your scope? Just barely? Or quite a bit? The next step down is 0.965" and it's noticeably smaller.
Edited by jragsdale, 20 May 2025 - 08:46 PM.
  • bekfromoz likes this
#3 hboswell
hboswell
  • Loc: Mississippi, USA
Posted 20 May 2025 - 08:43 PM
I thought the old Towas had .965" focusers? My old Tasco from the mid 80s (which I think was made by Towa) had a .965" focuser. If that's the case, you can get a .965-to1.25 adapter. I ended up replacing the focuser with a 1.25".
Harry
Edited by hboswell, 20 May 2025 - 08:44 PM.
  • Jethro7 and bekfromoz like this
#4 SoCalPaul
SoCalPaul
  • Loc: SoCal
Posted 20 May 2025 - 10:10 PM
I know they (used to) make hybrid diagonals that allowed the use of 0.965" eyepieces in a 1.25" receiver.
But it sounds like you need the reverse.
Can you return that eyepiece and hunt for one with a 0.965" barrel? Might be your best solution.
Clear skies,
Paul
#5 Elguen
Elguen
  • Loc: St. Louis, MO
Posted 20 May 2025 - 10:25 PM
Looking at the pictures in the other post your telescope almost certainly uses .965" eyepieces, you can find the for pretty cheap on ebay.
#6 bekfromoz
bekfromoz
Posted 20 May 2025 - 10:42 PM
Thank you!
I shall begin the hunt.
  • SoCalPaul likes this
#7 RichA
RichA
  • Loc: Toronto, Canada
Posted 20 May 2025 - 11:12 PM
Thank you!
Just measure the aperture of the focuser, once you find it's 0.96" then there are eyepieces available.  But, you can also buy adapters to go from 1-1/4" to 0.96" and that opens up a much wider range of eyepieces for you.
#8 hboswell
hboswell
Posted 21 May 2025 - 05:29 AM
If you want to consider the possibility of replacing your focuser, one just showed up on Classified that should work for you: https://www.cloudyni...nian-first-gen/
#9 eye relief
eye relief
  • Loc: North Branch, MN
Posted 21 May 2025 - 05:36 AM
Orion 0.965-to-1.25 Eyepiece Adapter
High Point Scientific has an adaptor on clearance! Orion brand
  • hboswell and bekfromoz like this
#10 DouglasPaul
DouglasPaul
  • Loc: Gold Bar WA
Posted 21 May 2025 - 07:52 AM
My 2 cents; enlarging the hole to accommodate a 1.25 focuser can be a pain. The .965 to 1.25 adapter may take too much focus travel away resulting in the eyepiece not being able to focus. Best just to find .965 eyepieces, at least to start.
  • ericb760, eye relief and bekfromoz like this
#11 SporadicGazer
SporadicGazer
  • Loc: SF Bay Area, CA, USA
Posted 21 May 2025 - 11:02 AM
  ... Best just to find .965 eyepieces, at least to start. ...
Probably depends on your goals, I'd argue converting the focuser or a hybrid-diagonal work better though they're more complicated or not easily available these days.  For historic accuracy vintage 0.965" EPs would be best, though finding them can be hard.
There are a few new decent 24.5mm (=0.985") EPs available on Amazon Japan, so less complicated solution:
First 9, 14, & 18mm Plossls (labeled OR for orthoscopic, but they aren't Abbe's):
https://www.amazon.co.jp/dp/B01BIQD7S6
A 25mm Kelner:
https://www.amazon.c...n/dp/B01BQ0BPCE
And a 40mm AH (Achromatized Huygenian.  AH is to a Huygenian what a Kellner (AR) is to a Ramsden):
https://www.amazon.c.../dp/B01BQ0RNMU/
#12 RichA
RichA
Posted 21 May 2025 - 11:20 AM
Also you can buy a hybrid diagonal for 1-1/4 eyepieces.
#13 DouglasPaul
DouglasPaul
  • Loc: Gold Bar WA
Posted 21 May 2025 - 12:16 PM
A 25mm Kelner:
I believe the scope is a Newtonian.
  • Kasmos and bekfromoz like this
#14 hboswell
hboswell
Posted 21 May 2025 - 01:10 PM
The Towa is a Newtonian reflector, a diagonal isn't going to help.
#15 bekfromoz
bekfromoz
Posted 21 May 2025 - 08:43 PM
Thanks so much for all that info.
I'm in Austalia, which unfortunately complicates most of those options. The Orion adapter, for example, with shipping ends up at $140
I've sourced a cheap alstar adapter. Won't have it for a week, but will the quality just make it not worth it?
#16 RichA
RichA
Makes it even more difficult, not likely having the focus draw of one of the old refractors.
#17 hboswell
hboswell
Posted 21 May 2025 - 08:46 PM
These adapters are pretty basic so I would think it would be at least workable. Meanwhile keep an eye out for some decent .965" eyepieces, they do exist. I spent lots of fun nights with my Tasco/Towa 4.5" Newt years ago. Wish I still had it.
Harry
#18 bekfromoz
bekfromoz
Posted 21 May 2025 - 10:26 PM
Harry
Thanks Harry. I really need all the encourgement I can get at this point. I want this to work so badly.
#19 ericb760
ericb760
  • Loc: Palm Springs, CA
Posted 21 May 2025 - 10:28 PM
I bought one of those for a .965 refractor. It didn't come to focus with it in. I ended up buying a hybrid .965 to 1.25 diagonal that works perfectly but that won't help OP with a Newt. My vote is to replace the focuser with one like the post above linked to.
  • SporadicGazer, eye relief and bekfromoz like this
#20 DouglasPaul
DouglasPaul
  • Loc: Gold Bar WA
Posted 22 May 2025 - 07:59 AM
That's crazy, I wonder what it costs to ship a small box from the US there?
#21 SporadicGazer
SporadicGazer
Posted 22 May 2025 - 10:10 AM
  ... I've sourced a cheap alstar adapter. Won't have it for a week, but will the quality just make it not worth it?
It shouldn't be a problem, these are very simple things and they'd almost have to try to screw one up.  (If fact I suspect there is one, or a very very few, factories spitting these out with only the silk-screen label changing per batch.  You'll probably get exactly the same as the recommended with the Orion label.)
OTOH- you will have a very unusual configuration if you can reach focus with the adapter as it add about an inch to the path and many focusers don't have that much extra range.  Good luck!
Also, it doesn't seem shipping from Amazon Japan to Australia would be any more than from Japan to the US so checkout decent (generic) Plossls in 24.5mm (0.965") I suggested above:
https://www.cloudyni.../#entry14144470
