Some users have reported that the little rubber pads at the corners sometimes catch on something. I've noticed this on mine, when it was mounted on a long QR plate. I added a couple of washers so the pads clear.
The little rubber pads around the perimeter of the bottom got caught for me as well and really messed up EQ mode for me. It turns out that my old leveling base solution for making it easier to level the Seestar for Alt/Az mode also works well for adjusting your polar alignment AND it solves the rubber pad problem as well by lifting the Seestar up off the surface of the mounting plate area so the rubber pads don't stick, 2 birds 1 stone
. Now I easily get 0° of error in both altitude and azimuth when I polar align and 30 and even 60 second subs are quite doable. 30 seconds definitely have fewer dropped subs, so I am sticking with that. I NEVER got 30 second subs to work well with Alt/Az mode, so this is a nice upgrade for me.
Details on how I set this up:
What I do is get the angle right on my wedge and then lock that in forever. For azimuth, I manhandle the wedge+tripod to point the Seestar exactly to the celestial pole on the azimuth axis. Fortunately for me the wedgepod+Seestar that I use is pretty light and easy to manipulate this way. Then I use my leveling base to fine tune the altitude which will invariably tweak the azimuth as well by a little bit, but the leveling base can do both so it works perfectly as the final step. I can move the tripod+Seestar to any location around my back or front yard and the wedge angle is correct (I could probably move it within 100 miles of my location and that would still be true). You could get a wedge with alt/az adjustments built in but I found the saddle clamp knob would invariably get in the way and I was not a fan of the "just use a comically long bolt with knob" approach. I had an old wedgepod to put my Seestar at the right angle and with the level I already had, this got the job done.
The Seestar is so much fun to use this way! I take it out with my other rig and the Seestar has more than an hour of integration done (and some pretty pictures) before I have even cooled down my C11 SCT, and I still haven't even started to polar align and fine tune my focus on my rig yet. And don't get me started on how heavy and cumbersome to move that C11+heavy duty tripod is
. Since I am just starting my astrophotography journey/torture, there are nights where I feel like I got nothing accomplished except debugging my rig, but now at least I have some nice data from my Seestar to show for it
I am now wondering if I could use my Seestar to do double duty as a polar alignment tool by attaching it to my C11's mount using a simple dovetail attachment to the Seestar and use the mount as a kind of manually adjustable tripod and wedge. I am guessing Sharpcap or NINA polar alignment with the cameras on the C11 attached to the mount would be more accurate, but it would be a fun experiment to compare the results. Probably cheaper to just buy a polar scope attachment, but not as fun
Here's a photo of my setup:
Clear skies
Edited by LightningMount, 21 May 2025 - 08:27 PM.
