when i first got my Mak 150 from Ioptron i wanted to try reducing the focal lenght as a test for galaxies.
i tried a bunch or reducers Antares 0.63, celestron 0.63 , Meade F3.3 , CCD67T 0.67 , Antares 0.5 2 inch ...
All of them caused huge flares on M57 , so thinking it was because i was to close to Vega, i moved way over to another targer and the same thing.
cloudynights members had a lot of ideas as to the cause , mostly it was the reducers fault.
So instead of giving up , i made a baffle tube , painted it with moosoo black flat paint and also the inside of the minuscus and around the primary ring.
Any thing that was shiny got a coat.
well , that did the trick. huge difference. i could flock the entire inside of the OTA but, no need at this point.
here are without any painting including baffle and the one i spent the day painting. plus my new Mak baffle glare reducer.
Before
After black paint application. Taken with the CCD67T @ 1399mm F9.33
Edited by starhunter50, 22 May 2025 - 12:57 PM.
