Oh, I get that. I'm just wondering what the power curve of the Power Tank is (lead-acid battery, BTW), because it kept the scope happy, but the MeLe quit at two hours. I'm willing to flatten out the curve some (that is, keep the output up) as long as I don't destroy the battery.
And this is what I hated in physics and what I hated when I set up the UAS program at a major railroad - figuring amps draw vs. Watt hours. In the case of the UAS program, the Federal Aviation Regulations use Watt hours to tell you how many LiPos you could bring on board - and, of course, the battery manufacturers use mAs to tell you the capacity. That was big deal for both our corporate jets ("Go-Team" events) and when traveling on business.
I don't own a MeLe and don't know which one you have, but looking at various ones on their website, the input voltage range is 12 to 20 volts. You are at the bottom end of the range as soon as you start and will drop below that minimum voltage pretty quick without voltage stabilization.
The lead-acid version of the Celestron Power Tank I saw online says it has a 84 watt-hour capacity. This is because it has a 12 volt 7 amp-hour battery in it. That battery can supply 7 amps for one hour, and the maths to convert to watts is 12 volts * 7 amps = 84 watts, so it will supply 84 watts for one hour. It's easier to use watt-hours when calculating capacity, like this: Say your rig draws 2 amps, 12 volts * 2 amps = 24 watts, that's 24 watts per hour (24 watt-hours). If your Power Tank can do 84 watt-hours, your rig will run for 3.5 hours, 84 / 24 = 3.5 , before the battery is dead. And keep in mind the published watt-hours are from Celestron's Marketing department, not the Engineering department, so the actual usable capacity will be less and decreases as the battery ages.
So you may have two issues, the voltage is dropping below the minimum input voltage requirements of the MeLe pretty quickly and even with voltage stabilization the total watt-hour capacity of your battery may not be enough to run your rig as long as you'd like.
I use a Jackery Portable Power Station Explorer 240, (240 Watt-hour) and can run all night. Scanner97's comment is spot-on. I think the Celstron Power Tank was meant to run a mount all night, but not a mount, cameras and PC.
Edited by XM381, 24 May 2025 - 07:13 AM.
