You need to be aware that your Polar alignment is a mechanical aiming of your telescope. That is its function and why we do it.
A Starting point.
So the more accurate you are with your Polar Aligning, the happier you will find you are later on.
Sloppy starts equal sloppy results.
When I subscribed to Sharpcap, I decided to do a little test one night. Purely for my own interest...
I did 10+ Polar Alignments with Sharpcap. Each one wanted for some adjustment. As far as I could tell, after doing things to a T, I wound up back where I started.
I just wanted to see what would happen. But minor tweaks each time was what I learned.
I've since learned that seeing variations also affect those results. And we really can't do much about that.
Now when doing my modeling (Star Alignment) after as good of a PA as I can, I've always err'd toward more Stars is better.
I reasoned I was giving my mount reference stars, you are aimed here. *
Just something I liked to do, call me an over achiever. I'm retired, I have lots of time.
I was explaining that to someone on the Gemini 2 forum on the WWW. And Rene` Grolsh, the creator of the Gemini 2 system for Losmandy Mounts posted he felt 10 or more stars were better than less stars.
So in my typical outhouse luck, I'd been doing good all along. With my AVX mount and now my Losmandy Mount.
The more you put into accuracy with your equipment, the more you can get out of it.
The less you put into it, the greater your frustration level.
I'd rather know I did my best.
YMMV
