The Lunt 16mm Flat-Field Eyepiece says on it's circumference that it's "optimized at 656nm". Does this mean it's a disadvantage to use it for nighttime observing? How would such an optimization manifest itself in nighttime observing?
Night observing with solar eyepiece?
#1
Posted 24 May 2025 - 11:41 AM
#2
Posted 24 May 2025 - 11:59 AM
As I understand it they've tweaked the coatings slightly. So, *IFF* everything else is perfect I guess it would be slightly worse than that same EP with equal quality conventional coatings. (But when has everything else ever been perfect? I'd just use it until I found something that worked better for me... or forever, whichever came first.)
- siriusandthepup likes this
#3
Posted 24 May 2025 - 12:11 PM
But ultimately it will work fine for general purpose night viewing. Perhaps not quite as good as some eyepieces on certain targets, but nothing to sweat over.
- Lucullus likes this
#4
Posted 25 May 2025 - 07:45 PM
Hello.
I have all 5 Lunt "Optimized at 656 nm" eyepieces. Got them for a very good price from Astronomers Without Borders a few years ago.
While I consider them excellent all-around eyepieces, with decent AFOV (especially the 19 mm) and good eye relief, I have always been suspicious of the so-called optimization for red light. To me the coatings looks quite typical. I have never detected any color tinge while using them. They are mechanically very similar to some "Flat Field" eyepieces once sold under a different name, but I was never able to compare the coatings.
That said, I have only used them for regular night astronomy and spotting-scope duty. That's because my 60 mm Lunt H-alpha (also bought from AWB) has a 7-21 mm zoom permanently in its case, and that works well. Cheers!
--Christian
Edited by ChristianG, 25 May 2025 - 07:52 PM.
