According to the specs, the TV-85 is 21.5 inches in length, the NP-101, 25.5 inches. 4 inches.. the big difference is the weight.
I think the 106 FSQ is the scope you want. 4 inch focuser, pretty short. The OTA does weigh 15 lbs.
The TV-85 measures about 18.5 inches without the diagonal compared to the 25.5 inches for the NP101is.
I actually browsed the classifieds today to see what FSQ106 scopes are available.
But I already use the 100mm f/4 Pentax SDUF Petzval refractor which weighs 8.4 pounds and is only 13 inches long without the diagonal. It's very stable on my small mounts. The Tak would need a larger mount, which I have, but I don't gain anything on the wide field observing end vs. the Pentax, even if I add the 0.75X focal reducer to the Tak.
What I've really been looking for (opened a topic on it a while back), is a shorter (than the NP127is) 5" Petzval, but there aren't many 5-inch Petzval refractor options. I trust Tele Vue quality, so I know the NP127is would be a great scope within its size and specs. I simply wish it was shorter.
And for those who mentioned Tele Vue's NP reducer in earlier posts, I've looked at that, but the back focus is only 68mm, so not enough for a diagonal.
Gary
