I thought I knew how to use PLOP but now when I try to see where it would place points on a 3 point cell it does not show any dimensions it says there are no parts and thus shows no dimensions. Anyone know how to make it work?
Can you design a 3 point mirror support cell using PLOP
#1
Posted 25 May 2025 - 12:14 AM
#2
Posted 25 May 2025 - 05:32 AM
#3
Posted 25 May 2025 - 06:35 AM
There are no parts in a 3 point cell because the 3 primary supports directly support the mirror. Parts refers to bars and triangles, which are only used in larger cells.
As Arjan says, around 40% radius is typical, but is non critical. Plop optimizes support only considering mirror deformation, which gives this number. However mechanical rigidity might cause you to want a larger radius.
#4
Posted 25 May 2025 - 05:57 PM
Thank you. So what you are saying is the contour maps and color maps and other metrics are based on that 40% radius.
#5
Posted 25 May 2025 - 06:07 PM
They are based on whatever radius and design you are modeling. If you are choosing to use an 80% radius, it will show that. If you are optimizing the cell and it goes to 40% then it shows that.
#6
Posted 25 May 2025 - 10:30 PM
I got lost. Where to you choose the radius.
Never mind I found it and figured out what I was doing wrong. I had only been using the automated option.
Edited by Dale Eason, 25 May 2025 - 10:34 PM.
#7
Posted 26 May 2025 - 04:20 AM
I wanted to add thank you David Lewis for that program. I have used it many years ago for several telescopes. At one time I even used the interferometer and my DFTFringe program to monitor a mirror in the mirror cell and added a little extra force on one of the support points by making it taller than the rest and then watched the simulated results from PLOP agree with the actual deformation.
- Oberon and davidlewis like this
