Hi everyone
I have owned a Touptek camera for about three years. It uses the IMX571 sensor. It is now branded as the ATR 2600 C. Until last week, it worked flawlessly and I have been thrilled with the results.
However, during the past three or four imaging sessions, it has started to drop sub-frames. On one night, it dropped about 50% of the subs. Last night it dropped about 35% of the subs.
This has never happened previoulsy.
I have tried different USB cables and have tried different ports on my laptop. The camera is plugged into my laptop - I don't use one of those mini control boxes. No wireless connections.
I have reset my laptop, which is three and a half years old. ACER ASPIRE 3. The camera has a substantial buffer [unlike my old CCD camera, which took ages to download subs].
I use the Touptek camera software for capturing images. It is a joy to use. Would using another programme make a differrence? As far as I know, I am using the latest version of the Touptek software.
The length of the subs does not seem to be an issue. Whether the subs are a few seconds long or 60 seconds or 200 seconds, there seems to be an issue with frames being dropped.
I use my camera at minus 20 degrees centrigrade.
I am at the coast in Cape Town, so weather might be a factor - I can see signs of corrosion on the springs that hold the cooling fan in the camera in place. We have had a lot of dew during recent nights, although last night did not seem as bad as previous nights.
I have made one change to my equipment, and that is that I have connected a Touptek electronic focuser to me scope, which draws power from the camera's USB port and connects to my laptop via the camera USB hub [on the back of the Touptek camera]. As I type this, I wonder if this is the cause of the problem? I have had the focuser for about a month, but have only imaged in earnest over the past week, due to severe cloudy weather in recent weeks. I can't test this idea tonight, as it is cloudy again. This seems like a long shot, as the focuser doesn't do anything whilst I am imaging - I don't have it set up constant refoucsing. However, I will disconnect it during my next session and see if that makes a difference. My guide camera also connects to my computer via the Touptek's USB hub - I use PHD guiding. The loss of subframes starts before I encable PHD, so I don't think that this is an issue.
Any thoughts on what might be causing the sub-frames to be lost?
Thanks for your help and advice.
Peter
PS I'm attaching an image of the Hamburger Galaxy [Centaurus A, also known as NGC 5128] that I captured recently.
