It also seems to blur a bit less toward the edges than my 30mm, but that could just be my imagination.
Simple five-lens-element widefield eyepieces based on the Erfle design are prone to the off-axis optical aberration known as astigmatism, especially when used in fast (i.e., low-focal-ratio) telescopes. They do perform well in slow telescopes, such as f/10 SCTs, however. Adding additional lenses to widefield eyepieces can counter astigmatism, at additional cost and weight, of course. Such eyepieces are referred to as being well corrected.
Astigmatism is another off-axis effect that causes rays from a star to come to different focal points in the vertical and horizontal plane. It elongates images horizontally and/or vertically, making them look cross-like. Its effects are especially pronounced when racking a star’s images through focus. Astigmatism is more likely to be found in very fast optical systems. It’s usually corrected with additional lens elements that vary spacing and stop down the optics.
https://www.celestro...ign-aberrations
It's a bit out of date nowadays but the article at https://www.chuckhaw...ece_designs.htm describes most of the common types of eyepiece designs.
