Siril conversion: preserving cr3 metadata
Astrophotography Beginner DSLR Software
4 replies to this topic
#1 n00btastic
n00btastic
Posted 09 June 2025 - 11:54 AM
I'm trying to learn Siril to stack and process my Canon R8 images, using 1.4 Beta 2's convert option to turn the .cr3 images into fits files first. When I run exitfool 12.40 on the source and destination files, I see I lose lots and lots of metadata that I'd like to preserve  (e.g. camera temperature) in the destination file.
Looking through the Siril docs, I don't see any options that seem relevant. Am I overlooking something? Is this a limitation of the fits file format? Or, is there another .cr3 -> .fit tool I should be looking at that will preserve all the metadata with conversion? I have a preference for Linux-based tools, but if the best options are Mac or Windows, I'd love to hear about them too. Thanks.
#2 prookyon
prookyon
Posted 10 June 2025 - 01:22 AM
FITS file format was never designed with the intent of supporting EXIF metadata.
As far as I know EXIF is largely not even standardized (a lot of the fields are manufacturer specific, not officially documented at all and tools like exiftool have just reverse-engineered their meaning).
To be fair FITS has kind of the same issue with various hardware / software living in their own bubble.
So even if some obscure tool has a way of stuffing it all into FITS - it might be the only tool that also can show/extract it properly afterwards.
#3 n00btastic
n00btastic
Posted 10 June 2025 - 11:53 AM
Hi, thanks for the reply. FITS does support non-reserved key/value pairs in its header (though with some length limits). I tested this out by using astropy to write an arbitrary key-value pair into a Siril-created .fit file. Siril 1.4B2 does show this data (open .fit file, right click, FITS header...) , and so does exiftool. So I do not think inter-application compatibility is much of an issue here.
But back to the original question, anyone know of a .cr3 -> .fit tool on any OS that preserves all the source metadata? Trying to avoid writing the Siril wrapper script to do this if I can.
#4 prookyon
prookyon
Posted 10 June 2025 - 02:49 PM
If you don't happen to find anything then maybe just dumping the exiftool output to sidecar text files or one concatenated file per folder? Assuming this is mostly for future reference.
#5 lock042
lock042
    Siril astronomical image processing software
Posted 10 June 2025 - 04:01 PM
Siril (and other software) uses libraw to read RAW files. However, many EXIF metadata are not supported. This is particularly true of metadata written in XMP blocks.
Also tagged with one or more of these keywords: Astrophotography, Beginner, DSLR, Software
