Hello!
I am located at a latitude of 44.5°N, and the Seestar S50 shows an altitude value of 45° when I switch into EQ mode. So that means I need to have the rough angle read as at least 44° to start the EQ mode calibration.
All of my calibrations end up high with respect to altitude, so I always have to adjust the Seestar away from the rough angle target. Consequently, I never have the opportunity to have it reevaluate again from my final setting. If I want to solve again, I have to adjust out of alignment to pass the first rough 1° requirement.
My question is if this is just a unique flaw of being located halfway between latitude degrees, or does everyone have this problem? I wish there was a way for me reprogram that initial rough value. Theoretically, I could set altitude once and then never again, instead of having to set it 100% of the time, and purposely make it worse to even get started.
Kevin S.
This sounds perfectly normal to me.
Keep in mind that you don't set your altitude angle to your latitude. You set it to the complement of your latitude, IOW 90-latitude. That's why you set your angle to level (zero degrees) at the poles, so you are pointing at Polaris (roughly speaking). If you set the angle to the latitude at either of the poles, the scope would be on it's side.
So being one degree off at 44.5 degrees latitude makes perfect sense.
But this whole thing gets even more confused because some wedges are numbered from the zenith. If that's the case, you actually use your latitude instead of the complement. Most if not all camera heads, like the one ZWO is selling, use the complement. Some astro heads like the iOptron or Skywatcher have zero at the zenith, but others don't. So you have to check whether, at level, it indicates zero or ninety degrees. Zero means use the complement, and ninety means use the latitude.
So, my best and totally serious advice is to get it close and then trust what the Seestar is telling you. It's taking pictures and plate solving to figure out your correct alignment, so it knows the correct position much better than you do. And calibrating the level of your S50 isn't going to make any difference about where it points you.
Good luck!
