clean, remove or apply new coat to the small mirror of the telescope
Posted 11 June 2025 - 04:38 AM
Posted 11 June 2025 - 05:11 AM
The one time my secondary mirror got really dirty -- for reasons to embarrassing to describe here -- I cleaned it with acetone, on the advice of the manufacturer (Rick Singmaster). It's an amazing solvent, but toxic, so use gloves and reasonable caution.
Posted 11 June 2025 - 06:45 AM
Posted 11 June 2025 - 07:43 AM
If it is dirt it might clean off. If it is rust, the coating is failing. Nobody recoats small mirrors, because it would cost 10x what the telescope is worth.
So yeah you can try to clean it and hope for the best. If that doesn’t work, you can continue to use the scope, understanding that performance is significantly degraded.
Unfortunately it is not dirt/dust
most likely it is silver oxide. I am also suspecting fungus.
Thanks everyone
Posted 11 June 2025 - 08:59 AM
Clean first, you never know. It looks like corrosion spots but maybe not. It might work surprising well for the time being if the rest of the coating cleans up OK and only leaves the nice round dark dots.
Posted 11 June 2025 - 09:15 AM
Posted 11 June 2025 - 10:16 AM
Thanks everyone
What is the size of the secondary? What scope is it from?
Posted 11 June 2025 - 10:53 AM
About 3.5" (9cm)
Posted 11 June 2025 - 09:42 PM
Posted 11 June 2025 - 11:23 PM
About 3.5" (9cm)
In which direction? Narrow axis or long?
Bill
Posted 11 June 2025 - 11:48 PM
Bill
I think it's for an SCT.
Posted 11 June 2025 - 11:50 PM
Bill
It is the same scope as the one in this thread
the prime/large mirror at the observer side while the small mirror we talking about is at the sky side .
the small mirror is reflecting the prism back inside a narrow tube located at the centre of the large mirror
https://www.cloudyni...meade-2080-sct/
Posted 11 June 2025 - 11:57 PM
I was just going to say that if the mirror was from an SCT it would either be from a C9.25 or a C11, but the secondary mirror on the C9.25 is a little smaller, and the one on the C11 is a little larger. I then figured it might probably be a Meade SCT, and so it is.
![]() Cloudy Nights LLC Cloudy Nights Sponsor: Astronomics |
