Backstory on my new scope/mount.
My scope showed up before I left on a week long vacation.
I was able to update the firmware with no issues, including the wifi module.
This is just the base CGEM II with the default controller it came with (Nextstar+).
Never used the scope cause I left on vacation.
My Autoguider showed up while on vacation and when I got back, I hooked everything up and went to update the firmware for the autoguider.
The firmware program ran through all connected devices.
I was doing this via the Wifi.
It kept telling me it could not update the mount now.
Tried again, same thing.
I hooked it up to my PC via the USB port on the bottom of the controller. Same thing, could not update the mount......then it could not find the mount at all.
Removed the USB cable, powered up the mount and the hand controller could not find the mount.
Getting errors 16 and 17 No Response.
I tried a few different things, but all with the same result. Dummy me threw away the box.
I worked something out with Adorama, and they sent a new mount. I am sending the "old" one back.
Hooked everything up, went to update firmware via wifi, everything updated and then got the can't update mount error again.
This is where I stopped cause I dont want a repeat of the first try.
When I power up the mount, the HC does find the mount unlike last time, so that is good.
Mount firmware version is 6.50.
HC: is 5.35.3179
I will be honest here, I am asking for some step by step hand holding here as I dont want to go through what I just did where the mount becomes completely unrecognized by the wifi and the HC.
I say that cause I did go here:
https://www.nexstars...pgradeHowTo.htm
But I am super nervous about hooking up that HC to my PC again, cause last time I did I "killed" the mount.
Can someone help me upgrade to 6.51, or help me understand what I am doing wrong and what I actually need to do?
Dallas has been nothing but rain, and on top of that I could not use the mount at all cause of what I did, so my point is I still have not even used this thing
EDIT: I forgot to add, when the HC stopped finding the mount, when I would turn it on, the mount would jerk slightly. Strange. Figured I blew the board on it or something, which is why I am sending it back.
Edited by Lardo5150, 11 June 2025 - 03:04 PM.
