Help Updating Firmware on Celestron CGEM II - Can't update Mount Error
Beginner Celestron Mount
30 replies to this topic
#26 Lardo5150
Lardo5150
Posted 12 June 2025 - 12:10 PM
Ok, I just decided to plug in the HC and try CFM to update again.
Not sure why, but it UPDATED!!!!
I am now on 6.51....But something else now failed.
See picture below.
I tried this through the HC, and I tried it through the Wifi module.
Also, which is which?  Which one is the actual Skylink Wifi Module?  I can't figure out what the actual version is from the Celestron site is supposed to be here.
#27 Lardo5150
Lardo5150
Posted 12 June 2025 - 12:43 PM
Strange,
It seems I am on the latest firmware version of the dongle.
I excluded it from the device list in CFM, and said my Wifi Accessory (AMW007) is all up to date.
I mean, I can connect to it with Skyportal and CPWI and it works.
Edited by Lardo5150, 12 June 2025 - 12:44 PM.
#28 frodus17
frodus17
  • Loc: Beaverton, Oregon
Posted 12 June 2025 - 01:23 PM
I ran into a similar issue on my 130 SLT mount and Nextar+ HC.
What I figured is somehow, if you update HC and MC (The CFM seems to update HC first, then MC), that it corrupts whatever it's flashing to the MC's and makes them inoperable.
I had to downgrade the HC using CFM first, then got rid of CFM. I used MCUpdate with older firmware and re-flashed the MC's. So it seems the MC's bootloaders were intact, but whatever was flashed was wrong/corrupted. Then I used CFM to update the MC's to the latest firmware first. Make sure you unclick the HC so it won't update that first! Then once the MC's were flashed, I updated the HC with CFM to the latest as well.
This seems to be a common issue with the order in which they flash and people getting 16/17 error. This was back in September, and I'm disappointed they haven't fixed the issue yet.
I hope this helps someone.
I posted my process here as well: https://www.cloudyni...tes/?p=13713646
#29 Lardo5150
Lardo5150
Posted 12 June 2025 - 01:30 PM
Ya, not sure why it all of a sudden "worked", but the HC and MC are both on the latest.  I just need to confirm that the two wifi pieces are on the latest firmware.  Specifically the Wifi Accessory (AMW007), cause I have the Homebrew dongle on the way :)
But if they are both on the latest version, then screw it, I am done, and going to look at stars......if this Seattle weather ever leaves Dallas.
  • frodus17 likes this
#30 mlord
mlord
  • Loc: Ottawa, Canada.
Posted 12 June 2025 - 05:40 PM
CFM does not yet include firmware for the "WiFi Accessory Bridge 3.5".  Too new.
#31 Lardo5150
Lardo5150
Posted 13 June 2025 - 06:03 AM
I forgot to do this yesterday....mlord, thank your for the help here.  I actually learned a LOT.
And thanks for the offer of flashing the board for me.
Also tagged with one or more of these keywords: Beginner, Celestron, Mount
