Now that I’m retired and have more time for stargazing I decided to upgrade from my Celestron Firstscope 76mm tabletop Dobsonian.
I was stuck analyzing too many choices when I saw a “National Geographic 102mm Sky Assist” on FB marketplace for $100cdn. Offered $80 and now it’s mine.
It seems to be 95% the same as a Celestron Omni 102 AZ but with different focuser and a weird thing that is supposed to talk to my iPhone.
The Red Dot Finder is way easier to use than the finder scope on my Firstscope partially because putting my head next to the table was hard. Two quick adjustments and the RDF was aligned with my eyepiece on a treetop about 400m away.
Eyepieces are way better than the Firstscope ones as well, though not as good as the Svbony 62 degree set I got to improve the first scope.
OK now the questions:
1) Is there a good way to improve the stability of the tripod / mount?
2) Can I safely tighten the locknuts on the AZ and ALT axis to make it tougher to nudge away from the target? Don’t want to risk damage by over tightening.
3) Anyone know what the device to pair with my smartphone actually does?
4) Would a better diagonal than the included plastic one make a difference?
5) It came with a really cheap plastic barlow, but I haven’t figured out why I would want even a good Barlow instead of just a lens with more magnification
If I do enough sky watching with my new $80 ($56 US) scope I’ll go back to pondering which significantly better scope to upgrade to.
Currently staring at a sky full of clouds.
Edited by Landau, 12 June 2025 - 10:13 PM.
