I wouldn't suggest buying a camera and ASIAIR if you don't plan to do imaging. As long as the HAZ is level you will get pretty accurate GoTo's. New users often complain about GoTo's being inaccurate, and I believe it because they are using the built-in bubble level which is horrible. After people recommend they use a torpedo level they are usually satisfied with pointing accuracy. The HAZ doesn't have a good spot to place a level on, so BEFORE you place the HAZ on tripod or minipier, level the flat top surface where the HAZ will be mounted. I suggest placing the tripod so one leg points South (or North), level in East-West direction first, then level in North-South direction last.
When you first get the HAZ you'll have to install the coin battery in the Hand Controller. That battery stores the Zero Position, the GPS coordinates, the Time Zone Offset for your location (in minutes), and the last alignment. So after installing the battery, level tripod and install the HAZ on it with iOptron logo facing North. The first time you run Align Wizard it can do some strange movements, so don't put the telescope on it, just power up HAZ and run the Align Wizard. Let it do its 2 minute "dance" and it will then go to a bright object like the Moon. Just sight along the saddle and when it seems to point at the target hit ENTER to align on it. Then hit MENU button and select PARK. It will aim at North horizon and ask you to turn power off (always park mount at end of night because that will make it fit in case).
From then on, the mount will remember its last alignment so skip the Align Wizard and use SELECT & SLEW to go to any object, then use SYNC to align on it.
I highly suggest using SkySafari Plus or Pro to control the mount. If you are purchasing the App, keep in mind that if you decide to upgrade they do not give you credit for your previous version, you'll have to pay full price. You need "Plus" to control the HAZ, but I'd suggest just buying "Pro" as you'll save money in the long run. If you haven't used it before, here's the procedure for Android:
In Device's WiFi Settings connect to mount's WiFi (probably begins with something like HBX8409). If asked select "this time only" and it will probably warn you will have no internet connectivity.
In Sky Safari MENU > SETTINGS > TELESCOPE > SETTINGS and deselect TILT DEVICE TO SLEW.
Then MENU > SETTINGS > TELESCOPE > PRESETS > ADD PRESET > OTHER CONNECTIONS and
select "iOptron CEM120" then NEXT (top right). Select "Alt-Az. GoTo" then NEXT.
Select Connect Via WiFi and set IP: 10.10.100.254 and Port: 8899
Then press CHECK CONNECTION and it should report "Connection Verified" (if not check that WiFi is still connected to HAZ). Press NEXT (at top) and enter a name for this preset (like HAZ46). Deselect Set Time and Location (will be set by GPS) then SAVE PRESET.
From then on, when you want to control HAZ from SkySafari:
1) In device's WiFi Settings, connect to HAZ WiFi.
2) Run Sky Safari and select SCOPE button, then CONNECT.
3) Select any object in SkySafari and GOTO it.
