I just acquired an Intes Micro Alter M715. I knew that wide field eyepieces don't work well with this telescope before getting it. I didn't know that its mostly because the rear aperture is only 24mm. If you use an eyepiece with a field stop > 24mm with this telescope, you get vignetting. So, I'm looking for eyepieces with a focal length of about 24-28mm, 52 to 68 deg AFOV and a field stop of not > 24mm. I'd like something with a field stop as close to 24mm as I can get. The best I've found is 22.8mm field stop in some Explore Scientific eyepieces. There's others with 27.2mm field stop and those might be acceptable as the vignetting would be on the very edges of the fov; I'd like to hear about your experiences with that if you have any. So, far I've looked mostly at the offerings from Explore Scientific and Televue. I'd like to hear suggestions from other manufacturers that you may know of. I don't care if the barrel diameter is 1.25 or 2". Its the field stop diameter that matters.
It sure would be handy if retailers included the option of using field stop diameter as a search variable on their websites. hint hint.
I already have a couple 18mm eyepieces I can use with this telescope but I'm wanting something that's going to provide less magnification with this telescope. I'm going for about 100x mag. if you also have any suggestions for eyepieces that will provide about 50x and has a field stop <= 24mm, I'd like to hear about those too. Iirc the focal length of the telescope is 2670mm.
I have had an f12 mak for awhile but I've never had any experience with an f15 mak. So, I'm not really even sure how well eyepieces with an afov in the 62 to 68 deg range will work but I'm willing to try. I don't want to go up to 82 afov (as much as I like those) because I want to maximize image brightness as I'm hoping to also use this telescope on globular clusters, planetary nebulas and galaxies, and maybe the occasional comet. Seeing conditions where I typically observe rarely let me get above 150x mag. So, I'm basically looking for eyepieces to give me 50x, 100x, and 150x mag. Well, and maybe 200x but I do have a 2x focal extender.
BTW: if you know of any great threads here on CN regarding collimating these particular telescopes, please indicate some. Thank you. I've heard these are challenging to collimate. I've read the dissection thread already- very useful info there.
Edited by Mossonarock, 13 June 2025 - 01:45 PM.
