Getting oval stars in corners after reassembling apo with reducer
9 replies to this topic
#1 Starspawn
Starspawn
Posted 14 June 2025 - 11:32 AM
Hello. I am using a reducer/flattener on a Sharpstar 76 and it was working nicely with reducer, I was getting nice, round stars on all parts of the picture. Then I ran into some trouble with focuser and I disassembled and reassembled the whole scope and after that I'm getting oval stars in corners of my photos (here is an example: https://ibb.co/PGzZ6Vg1).
I tried repeating the process, to make sure I screwed everything correctly, I think I did and it's the same. Any ideas on how to fix that?
#2 Celerondon
Celerondon
  • Loc: Southern California
Posted 14 June 2025 - 12:32 PM
The image that you linked is not visible.  Did you know that you can upload images to an Album in your Gallery on Cloudy Nights and avoid this issue altogether?  Once an image has been uploaded then you can display it in your post by clicking on the My Media button in the post editor toolbar.
Don
Haleakala Telescopes
Edited by Celerondon, 14 June 2025 - 12:35 PM.
#3 Starspawn
Starspawn
Posted 14 June 2025 - 01:05 PM
Tnx, here it goes:
M51
#4 Yomamma
Yomamma
  • Loc: North Central Florida
Posted 14 June 2025 - 09:38 PM
Check your backfocus from the reducer to the camera
#5 RetiredDave
RetiredDave
  • Loc: Wilmington, NC
Posted 14 June 2025 - 09:49 PM
Did you measure the elongation? Looks like there is more elongation in the upper left corner. In addition to backspacing, check for tilt. Tilt may have been introduced by the disassembly/reassembly.
#6 Starspawn
Starspawn
Posted 15 June 2025 - 09:58 AM
It should be fine, 5,5cm, I wasn't changing anything here IIRC. I did try adding those tiny spacers, will test in 2 days when I get clear skies.
I don't know how to measure the elongation (I don't have PI). Yeah I already checked for tilt and I don't see it with naked eye.
While googling on how to measure the elonagion I found out couple of other possible causes, one of them being ventilator from camera cooling, will try with cooler on off.
#7 Tapio
Tapio
  • Loc: Tampere, Finland
Posted 15 June 2025 - 10:06 AM
You can test tilt with ASTAP, which is free software.
#8 Starspawn
Starspawn
Posted 18 June 2025 - 08:02 AM
Ok this is the result, but I don't know how bad the numbers are and if this is what is causing the elongated stars
tilt
#9 Tapio
Tapio
Posted 18 June 2025 - 08:20 AM
The numbers are good, and as you can see at bottom 'Tilt (4% none).
But maybe you need to tweak back space distance.
  • Starspawn likes this
#10 Starspawn
Starspawn
Posted 18 June 2025 - 08:37 AM
Oh, I didn't notice that. Well that's good news then. So then it's the backfocus I guess. When I check for distorsions in Siril it's really bad. It's weird because I don't know what could have caused it. I just disassembled and reassembled the scope, everything is the same.
