Clouds finally cleared enough to do a test run with my National Geographic / Explore Scientific Skyassist 102.
The plan was to practice using the red dot finder. But when I reached for the on/dimmer control dial and gave it a couple of turns I realized I was turning one of the alignment screws. Tried to turn it back to original spot but probably wasn’t close. A few attempts at using the RDF to put a bright star in the eyepiece failed miserably so I switched to just using the slow motion controls to centre random stars in the eyepiece. Really licked the slow motion controls. Much easier than my Celestron Firstscpoe.
What I learned tonight:
I really like this scope. It is better in every way than my Firstscope
I need to memorize where the on dial for the RDF is.
Putting the tripod on grass, rather than concrete, as tornado suggested in my original post, made the scope much more stable.
it is much easier to observe from a chair than standing
Even though I didn’t accomplish much it was a lot of fun.
Next on the agenda (in random order after the first item)
Align the RDF and repeat the plan
Order a better diagonal to replace the cheap plastic one
Improvise a phone mount so I can use Astrohopper to find objects
More observing!
Figure out a good weight to add to stabilize the tripod more
