Hello
Whichever scope you decide to go for, I think you'll enjoy the views and have a wonderful time using it.
I can assure you that if you get into amateur astronomy, more scopes will follow so this won't be your only and last scope .
If I may add a few more thoughts to all the excellent advice here...
Well, I am nearing a decision. I believe I am going to buy either:
1. Apertura AD6 dobsonian;
2. Celestron StarSense Explorer 6" dobsonian; or
3. Celestron StarSense Explorer 130AZ (5" )
That's the choice.
I have somewhat backed off the 8" dobs simply for future considerations of my own aging. Maybe that's a mistake, but I believe the 6" may be more portable and manageable for me as time passes. Feel free to disagree with me because I understand the light gathering advantage of the 8" scope, and price difference between the two is not a consideration.
If you can store a Dob in a garage or at ground-floor level, the way to move a Dob around is with a hand truck. It's no effort at all. I never lift the OTA and base together so you want to look at the weight of the individual parts, not the combined weight. The AD6 and AD8 are both the same length and take up as much space in storage.
6" and 8" Dobs are readily available for sale used so if you're not sure, you could just get a used one. If you don't like it, you could probably sell it for the same price and get something else that suits you better?
For planetary viewing on a non-tracking mount, I find a magnifying finderscope essential because you can easily find it back using your finderscope. The alternative is to change eyepieces back to low power, which is a bit of a pain. Something to be aware of if the StarSense 8" Dob makes it back to your list.
Question to others: Doesn't the Celestron SSE 130AZ use Synta's stock 130mm f/5 Newtonian that's got a mirror that's sometimes spherical, sometimes parabolic? Perhaps others with more knowledge can comment?
Wow, Pi finder is only $540.00?
Seriously, how can anyone recommend that to a new user?
For others reading the this thread in the future:
I agree that the PiFinder might not be for the beginner. If you have a 3D printer and a soldering iron, you can assemble one for €290. It's still a lot of money. Cedar e-finder is cheaper to build. You interface to it using your phone & SkySafari.
Good luck
Tak
