Stacking takes place on the Seestar, not on your iPad, and if you're not going to save the individual frames, each image is going to be about 1 MB. If you save each frame, they're about 4MB each.
I thought all iPads have GPS these days. The Seestar needs to know its location, and it gets it from your iPad. If you don't have GPS, your iPad will use your WiFi connection to figure out where you are. If that fails, it will use your ISP's location which could be crazy far away.
You can build a custom AP rig from components with a ZWO ASIAIR as the controller. The software will run on your iPad and will be very familiar once you're used to the Seestar software. If you're thinking long-term uses for this iPad, I wouldn't skimp on it. They get obsolete quickly enough without you buying one today that just gets you by then wanting it to do more in 2-4 years.
Even if you were to save all your subframes so that you can stack frames over multiple nights, none of that happens on your iPad. In fact you can set up a shooting plan on your iPad, get it started, then turn off the iPad and go to bed. The Seestar will shoot while you sleep. Then wake up in the morning and check the results by reconnecting your iPad. So the performance of the iPad doesn't matter. You're only using it to view images, not process them or actively drive the Seestar. And the images from an S50 aren't that large. 1080x1960 is the normal size; 2160x3920 at the full mosaic size.
Thanks. I think the iPad Air is worth it especially at the current sale, which narrows the gap. It also has USB 3 for what it's worth. I was initially going to build a custom rig and just connect my PC directly to the camera, but the cheapest decent option would be $2k more, so I decided this would be a better learning route. The ASIAIR and an iPad would be another $1k on top of that but more convenient; my laptop is a heavy power hungry gaming device. I guess there is a 3rd party app for connecting a PC to the Seestar although it seems like it's finicky netting it set up right.
True, the resolution is small on the Seestar which is one reason I had avoided it, but it's certainly sufficient for EAA. But I will still get at least 256GB. It seems some people like to download all the frames to process in another app, although I was mainly thinking long term about stacking with a custom rig. But now that I think about it, I remember reading last year that there weren't any iPad apps for processing, which surprised me.
No, only cellular iPads have GPS, which is frustrating. That's one reason I didn't get one a couple years ago when I had a Celestron Evolution. That version would be $750 plus monthly fees.
So this presents a dilemma. Maybe an Android is a better option, it seems some of those have GPS without cell but I need to check.
I see MacBooks are on sale too, a comparably equipped model with 256GB storage and the M4 chip is $850. Can you connect that to a Seestar, but have the MacBook get its location from my phone? Not sure if that version is enough to run any stacking software down the road; I guess SharpCap would have to run under a windows emulator.
Ugh.
Edited by Craig Smith, 16 June 2025 - 11:54 AM.
