I decided to get out the EQ5 Pro mount that I haven't used yet for imaging. I put the Quattro 150 on there which is around 12lbs. ASI585 camera, coma corrector, asiair, guidescope and camera. The total of all of this should be less than 20 pounds.
Polar aligned and focused, only to have guiding just stop and basically freeze the asiair.
I'm running the EQ mod cable directly into the asiair.
This OTA has a focal length of 517mm and maybe that's too much?
After trying to calibrate guiding with no success, I put the scope on the AM5 and polar aligned and all was fine. I did find about 2 or 3 subs where tracking was off though out of around 250. So 2 good nights with the AM5 and no real problems.
Is the AM5 that much better than this EQ5 Pro? Maybe if I put my refractor on there that has a 400mm focal length it won't have to struggle as much? That setup would likely be half the weight.
I did have 2 weights on that mount and had it balanced as well. Probably will only need one of the counter weights with the refractor.
