Best diagonal for 8" (200mm) F5
5 replies to this topic
#1 rjng
rjng
Posted 16 June 2025 - 10:21 AM
Dear friends, hope you are all well!
This is my first post here, hope you understand me. I searched the forum and, although I found some relevant information, I still don't have confidence in my final answer.
I currently have a Svbony MK105, and thinking about an upgrade, I decided to try to build my first telescope, but keeping my Sky Watcher Eq GTi mount, with a load limit of 5kg. Therefore, I don't have many design options.
Luckily, I found a very cool project on the internet, called Leavitt, available on Printables, for 3D printing that fits my case. This project uses a 203mm (8 inch) primary mirror and a 54mm diagonal.
Another contributor made a remix of this project specifically for use with his mount, which is the same as mine, with the aim of making it lightweight, using few materials and carbon fiber tubes, in addition to using hardware with metric measurements, which for me was very good. In this remix, a 200mm primary mirror and a 62.5mm diagonal were used, and the choice of the diagonal size was based on a diagonal calculator website and also on a table of diagonal size suggestions from GSO, available on the Agena Astro website .
I've already printed and assembled the entire hardware, just needing to buy the mirrors, and that's where I got stuck. So far it weighs 1830g.
My question: I think this diagonal is too big.
As a beginner in building these toys, the only thing I have in my favor is a little bit of geometric notion and a little bit of CAD knowledge. If you can, follow my reasoning:
When I use the principle of similar triangles, a diagonal of 62.5 mm causes the focal plane to be 312.5 mm from the center of the telescope tube. Considering that the outer diameter of the telescope is 218 mm, the focal plane would be located 203.5 mm from the tube, which seems like a lot to me, considering that the focuser is significantly smaller than this. In the figure below, I present a full-scale diagram of the telescope, with the pink light beam naturally converging towards its focus, but being deviated at a certain point where the cross-section of the truncated cone delimited by the light beam has a diameter of 62.5 mm, thus causing the focal plane to be far from the tube.
At the same time, according to my calculations, using the focuser model that I printed, the center of the focal path would be at a distance of 24.5 mm from the tube, which I considered a reasonable point for the focal plane (correct me if I'm wrong). From this, I was able to calculate the distance from this supposed focal plane (in green) to the center of the telescope tube (red line) and then calculate the diameter of the light cone cutoff, obtaining 26.7mm, which is much less than the colleagues mentioned calculated.
See, nothing prevents me from using the 62.5mm or 54mm diagonal, but I understand that, geometrically, in order to obtain the proper focus, I would need to position the diagonal at a certain distance from the primary mirror, which would inevitably cause a significant and unnecessary obstruction of the light beam, so optimizing these sizes would be a good idea.
Considering my inexperience in this type of project, and not having many colleagues to be able to discuss it with in person, I was sure that I would find this answer here. What is the error in the reasoning above?
During this simulation, I came across another issue - when I place a 26.7mm diagonal at the center point of the telescope, in the 3D view it is possible to notice a phenomenon that must have a name, but I don't know it, which is part of the light beam escaping from one of the edges of the diagonal, while the opposite edge of the diagonal does not receive any light, but on the contrary, it just ends up obstructing the arrival of light to the primary a little more. This occurs because when rotating the diagonal by 45ยบ, the end opposite to the focuser approaches the primary, in a region in which the cross-sectional diameter of the light cone is larger, while the end close to the focuser moves away from the primary, in a region in which the light cone has a smaller cross-sectional diameter.
The another question is: how relevant is this? The diagonal size will not be exact, and will depend on the commercial size options available and maybe a will have to buy a bigger one anyway. But, with the 3D printing tool, I could easily slightly shift the center of the spider to optimize light reflection, like this (shifted 1.3mm):
If the purpose of using the telescope is important to answer my questions, I can say that I would like a versatile telescope for visual observation, with my eyepieces and barlows and, eventually, as I evolve, perhaps start astrophotography, even for deep sky. I know that with the use of photographic equipment I may need to change some focal issues, which I do not yet have full knowledge of. I agree that an F5 is not one of the most versatile telescopes, but due to the limitations of equipment and money, I believe it will be possible to make good use of it for a while, until the next project!
I would like to thank the colleagues on the forum in this stage of my life as an ATM apprentice, and I hope to soon be able to resolve my problems and order my mirrors!
#2 mrowlands
mrowlands
  • Loc: WI
Posted 16 June 2025 - 10:55 AM
The table on Lockwood Custom Optics website might give you some ideas:
https://www.loptics..../diagonals.html
Mike R.
  • cookjaiii likes this
#3 Bob4BVM
Bob4BVM
  • Loc: W. Oregon
Posted 16 June 2025 - 12:52 PM
Hello Rjng, Welcome to CN !
Typically we start with the mirrors and build a structure around them.
I would highly recommend that you start by running your design thru Newt for Web, it will answer all your optic system questions and allow some options for a given system. We typically use this to design a telescope structure, for a given mirror set's specs.
Go here : https://stellafane.o...b/newt-web.html
So is that a picture of your completed scope structure ?
Is the red part a dovetail from which you plan to support the scope on the mount ? Would be good to see how the whole scope/mount goes together.
First thing to consider with a structure is that it must hold the primary, secondary, and focuser in a very rigid, precise alignment, at all altitudes from say 20* to zenith
CS
Bob
Edited by Bob4BVM, 16 June 2025 - 12:56 PM.
  • AndresEsteban likes this
#4 rjng
rjng
Posted 17 June 2025 - 06:19 PM
Hello mrowlands, thanks for the tip. The text is explanatory and cleared up some doubts, talking about not making a diagonal too tight in its dimensions, as well as the issue of the displacement of the center of the spider. The available table summarizes the time of their experiences in this process and it is smart to follow. Thanks!
  • mrowlands likes this
#5 rjng
rjng
Posted 17 June 2025 - 06:27 PM
Hello Bob4BVM, yes, the picture is from the finished structure, including the suggested spider with 62.5mm secondary. The red part is made of metal (from AliExpress), a dovetail that fits into my current mount, which has already been tested, although I still have concerns about the stability of the set, since the telescope will be long and could, in some way, exert a moment of force that could topple the tripod depending on its position. Tests will be necessary. Another point is the flexibility of the 3D printing material, associated with the flexibility of the carbon fiber tubes, which can bend the set as a whole. However, some people have already built this model and given positive feedback. The website mentioned is quite complete, I could simulate my measurements and it seems that, although not ideal, it will have acceptable performance. Thank you!
#6 triplemon
triplemon
  • Loc: Portland, OR
Posted 17 June 2025 - 11:20 PM
Here you can simulate the exact illumination resulting from your secondary vignetting.
https://www.bbastrod...ner.html#visual
62mm secondary is pretty big for visual. over 31% obstructed. 54mm seems more sane.
Edited by triplemon, 17 June 2025 - 11:22 PM.
