Thanks antarex. Yes, for Venus it doesn't seem like there's much issue with the filter, although the IR leak is actually significant (especially for Mars) as discussed here https://www.cloudyni...3rd/?p=14148987.
Mars has stronger IR dark features than it does in UV, while IR cloud features of Venus are stronger in the UV. But Venus UV features have to be muted in contrast to some degree by the IR leak.
Over 15 years ago Baader 1.25" U-Venus filters were found to have an IR leak, but their 2" versions did not (IIR, there was a substrate difference that Baader then fixed). The leak appeared as a contrast-robbing overlapping ghost image that would easily misalign enough due to atmospheric dispersion to be easily seen when Venus was quite low. A friend of mine (Sean Walker of Sky&Telescope) had the problem 1.25" filter --- he had been gifted the filter by Baader for a project he was doing for them, and after he identified the leak they sent him a 2" version. He knew someone who had the proper tools to cut a 28mm disk from the 2" filter which he remounted in the 1.25" cell, and that's the UV filter he still uses today.
Edited by John Boudreau, 17 June 2025 - 10:29 AM.
