That is such a general and vague description I’m not sure how you’d expect anyone to give you a definitive answer. The Fusion is a mini-PC, so it’s going to do mini-PC things. The problem could be hardware or it could be software. Can you make it boot off of an OS on a USB stick and it will stay up? Have you tried asking Software Bisque, its creator and vendor?
Thanks for the reply. I am just describing what I have observed. I set it up as a stand alone to configure and got some joy. It loads all the software and saves the parameters I set, (from the manual), It then started rebooting randomly. I got through to SB and they suggested trying a CAT5 cable to see if the WIFI is working. That stabilised it a bit and I got the "Ready" message. I was able t navigate the the FUSION home screen and Imaging software without problems and it seems the software is all there.
Unfortunately, the stability didn't last and I am back to random reboots again. I even disconnected screen, keyboard etc which has made zero difference. The "error", (most likely my ignorance), seems to change a bit as I fiddle but it's still giving me the irrits...
Pre-Covid, I was pretty tech capable but I have copped some serious memory damage, (abt 30% just GONE), and have lost most of those skills.
Thanks for the input Dan. It meant pretty much nothing to me
, but I'll try to relearn this stuff.
My gut instinct is that its all functional but running the original image of the S.W.. Been quite a while since I have been able to get my gear out at all.
