"I finally took the plunge and bought the Nexstar 8SE which has everything I imagined. The only thing missing is the description of the added screws on the 'rear cell' (6: 2 left, 4 right). Celestron.com and most all other pictures don't show any except the two default ones for the red-dot finder.
I have found in Celestron.com 'reviews' show (Sonia R.
03/02/2023) an update picture showing two of the new screws (2 left).
Question; are these threaded holes for additional mounts or are there nuts attached inside and used for ___, if unscrewed the nut will drop and can't be reattached?
example: add 8x50 finder, StarSense, move red-dot finder left
On one CloudyNights forum it was suggested about the screws on the rear cell had nuts attached inside, if unscrewed the nut will drop and can't be reattached. Bad!
Again, your forum entries have helped to answer many questions and described many issues. Thank you everyone!
