So you have a 22mm Nagler?
That has a 31.1mm field stop.
Going by the "rules", the next logical focal length lower than the 22mm would be a 31mm eyepiece with a 43.5mm field stop.
The closest you can get to that is a 31mm T5 Nagler.
Your CPC has a 2795mm focal length, so 22mm = 127x and a 31mm would be 90x. That is a very nice spread--noticeable in terms of magnification and brightness.
After 31mm, 43mm, though most SCT users use a 40-41mm instead, or jump to a 55mm Plössl to get the largest exit pupil.
I can't see that any eyepiece in between the 31mm and 22mm would get any use--the magnification would be too close to the 22mm.
That's with the SCT. In the refractors, the magnification change would be so small as to barely be noticeable.
There's a reason why the 31mm Nagler outsold the 26mm by 20:1.
I'll leave you guys select me 5 eyepieces from this list for each of the first 2 refractors. The SCT I own is fully covered.
Anything over 6-6.3mm Exit Pupil is not of much use from Bortle 8-9, decently dark backyard.
I want 5 eyepieces out for the night, and don't care if the magnification difference is minimal. That's my problem.
I don't want anything less than 2.8-2.9mm Exit pupil and max 6.2mm Exit Pupil. So best to split them by 1mm of Exit Pupil...
2.8-3.8-4.8-5.8 and one in between all that for good luck.
Blue I own, Light blue I'm thinking about. Green means not fun to look through, washed out sky.
Although I've noticed when that moon is gone, I can go up to 7mm exit pupil, even the 48mm Brandon gets to come out, so there's that also.
I always wanted to try Jon's big easy view smoothie 32mm TV Widefield so don't discard it lol. The 32mm Panaview I might try and like also.
PS> I tried several refractors in the last 2 months, from 92mm APO's to 110mm ED's
thinking that my 100mm Achro was a cheapie, and you know what? I ended up
liking it best over all of them for very low power. Go figure. That 92 APO was a killer scope though,
but probably best suited for someone that lives in a darker zone. The 110 ED was a bit too long and heavy at 15lbs
for my 14.5lbs max cap mount. I ordered one final 120T to try out also. It's longish but weights much less than the 110ED.
That Bresser I'm selling, but if no one buys it, I'll gladly keep it,
what a nice fun scope to own, so light too. It's just hard to make an ep set with it.
I use the TSFLAT2 with all of these scopes, works real great!
Would love your guys thoughts on a 27mm Panoptic vs the 28mm AT82 also.
I'm not 100% sold on my 28 AT82 yet, but it's such a nice build and has great
color transmission. I think i'll look for a 27mm Panoptic and a 26mm Masuyama
at some point, try all 3 and sell 2.
That 38mm Panaview, I'll use in the SCT as well, but it's great with the 100mm refractor
when there's no full moon coming up from the east. Sold my WO 40mm to keep it,
although they were probably the same eyepiece. That WO 40mm was not bad at all
in the SCT, huge lens and very comfortable but the Panaview has a much better eyecup for me.
The 40 UO was good, didn't like the metal edges touching my cheek.
But good eyepiece, didn't notice any aberrations. Nice lens.
Felt cramped though for some reason compared to these 2 though.
Love me some true color Achros baby.
Edited by Procyon, 17 June 2025 - 11:19 AM.
