I bumped the GSO style focuser on my Orion ED80T CF so now the fine focus knob wobbles and spins freely. I’ve had no luck trying to straighten it by carefully bending the knob or adjusting the shaft with the inside focus mechanism. Can anyone suggest an alternative way to true its shaft or whether I’ll have no other option other than finding a replacement focuser?
If it has to be replaced, what dimensions are actually needed to size the replacement in the same price range?
Mine pushes on to the tube and is secured with 3 hex socket screws.
O.D. is 83mm
I.D. is 73mm
Height of its body is 65mm
Length of the draw tube is 150mm with 90mm travel, and
reaches focus at about 30mm.
What dimensions are actually necessary?
