My newbie hat is on for this question, so pardon if there's an obvious solution I haven't found on my own; I promise I searched first
The situation:
I have an equatorial mount (on a tripod) that is semi-permanently located on my apartment roof. Once it's set up and aligned, I will not be adjusting it's location very often if ever. I don't have a permanent pier for it and can't necessarily install it. Also lugging something cement up 4 flights of stairs sounds like an unfun task
During the summer (now), my city gets to around a Bortle 7.6+. Depending on the Moon and other lights, seeing Polaris can be a bit of a struggle with the naked eye.
My only telescope (see below) is a 1000mm refractor with a 9.8f.
I'm having difficulty getting a polar alignment, which is kind of cascading problems...
- In order to be able to polar align via three-point plate solves (NINA), I need a minimum number of stars visible and roundish stars.
- In order to have a minimum number of stars visible I need longer exposures (due to high F ratio and light pollution), which requires a good polar alignment to not blur.
I tried it by hand with a polar scope but I wasn't able to manage it very well due to the difficulty in visually seeing Polaris.
I also tried with the guide camera instead (SV905c) through a 60mm guide scope but it really wasn't up to the challenge. Too much noise. Works fine for guiding but can't get a plate solve in ASTAP off it.
My next idea is to slap my DSLR and 200mm/f5.6 lens on top of the mount and try to align with that. The lower FL should make it less prone to alignment blur for initial setup, and I can pump the gain pretty high on it while wide open. I haven't tried this yet, waiting for a clear night.
Am I on the right path? Any alternative methods I'm missing?
Edited by Alay, 18 June 2025 - 10:24 AM.
