Thanks Don, I think that sums up the mirror cell support analysis quite nicely.
It was my understanding that while a 6 point cell is much worse than 18 points, the difference in RMS is within what is considered perceivable.
This is from the GuiPlop Users Manual:
"A reasonable limit for the RMS error due to the mirror cell is about 1/128 wave, which is about 4.2e-9
meter, or 4.2e-6 mm, for 550nm green light. This means 1/64 wave on the wavefront reflected from the
mirror, and corresponds to about 1/16 wave peak to valley. This is based on Toshimi Taki's suggestion that
about 1/4 of the error budget may be allocated to the mirror cell."
I'm wondering if you could provide any insight on this?
Another question this brings up for me: How do I determine what rms error threshold I should be considering?
Here's the info on the mirrors:
Hubble optics: 1/10 or better in PV, about 1/50 in RMS, and 0.95 or better in Strehl ratio, with the 96% enhanced aluminum coating
GSO: GSO guarantees diffraction limited performance, but their mirrors typically have a mirror surface quality of 1/16 wave RMS at least, with 92-93% coating.
Most after market tests show that these mirrors *barely* meet the Maréchal Condition (0.80 Strehl), and some do not.
So I would think it wise to add as little as possible from errors you can prevent.
The eye is most sensitive at night at ~500nm due to the Purkinje Effect, which increases the error in the mirror because of a shorter wavelength.
(one of the reasons I don't like to see interferometric analyses done with a red laser at 650nm. A 0.05 wave error at 650nm is 0.065 wave error at 500nm).
A "system" (mirror cell, sling, primary mirror, secondary mirror, eyepiece) that yields 1/4 wave P-V on the wavefront, in good seeing, will yield good images.
If you start out with a primary mirror that is 1/4 wave P-V and then add to it with errors from other sources, then the final wavefront will be poorer.
It's why I recommend the most accurate secondary you can afford, and to minimize errors from the mirror cell and sling.
Admittedly, Seeing conditions often make the best optics mediocre, but we deal with what we can control.
I'm not comfortable with the hardware adding 1/16 wave P-V. Maybe that's because I've had higher end mirrors for decades.
Maybe it's because the scope builders I used made scopes with low error mirror cells.
It's also a matter, obviously, of how thick the mirror is. The 2 mirrors you contemplated had very different thicknesses: 8% and 12.5% of aperture.
At that aperture, temperature equilibrium is required for the best image quality, so the thinner mirror would have the advantage.
And, since you're the designer, add both a rear fan and some cross-vent fans and you will see what the mirror can deliver a lot sooner in the night.
I just sold a 12.5" scope with a 32mm thick mirror and it cooled very quickly with 3 fans, and stayed at the ambient temperature all night.
My previous 12.5" scope had a 55mm thick mirror and even with a fan, it didn't get to equilibrium until after 2am with the fan started at sunset.
I'd go for the thinner mirror. It'll be easier to transport if leaving it in the mirror box during transport.
Edited by Starman1, 19 June 2025 - 03:45 PM.
