lx90 8" LNT Orthogonality adjustment
8 replies to this topic
#1 Blackmyst
Blackmyst
  • Loc: Kyalami, South Africa
Posted 19 June 2025 - 06:50 AM
Hi all
I've been putting off adjustment of my scope for a while (over 10%), however after reading some of the guidelines on CN I've decided to move forward.
I see there are threads on the rear edge of the dec mounting plates for grub screws which will push against the DEC mounting plate screws (adjustment), but I have not been able to identify what size grub screws (or socket head screws) these are.
Based on the other screws on the scope these would be imperial and unc, but I'm not sure of the exact size - near as I can tell they're around 2.4mm (3/32).
Does anyone know what the size they should be?
regards
#2 Blackmyst
Blackmyst
Posted 20 June 2025 - 04:07 AM
for those curious to the method, see here - https://www.cloudyni...ity-adjustment/
#3 Piet Le Roux
Piet Le Roux
  • Loc: Bloemfontein, South Africa
Posted 20 June 2025 - 05:52 AM
I am still curious and I have looked at the link and found that very confusing! I would appreciate some clarification of what is being adjusted?
#4 MikeBY
MikeBY
  • Loc: Huntington Beach, CA
Posted 20 June 2025 - 06:22 AM
What is being adjusted is the optical axis of the OTA to be orthogonal with the ALT and AZ axis of the mount to reduce/eliminate cone error.
The screws are definitely SAE English thread although I couldn't tell you definitively what size.
I agree that if clearances allow,  use a longer cap head screw rather than a grub screw and leave them in place to keep tension on the threads.
I wouldn't think that focusing on a spot on the RA axis would be precise enough.
Perhaps an artificial star or laser collimation tool. with the scope on an optical bench, or very precisely leveled bench.
Then you can adjust by rotating AZ and ALT through precisely 180°
Adjust out 1/2 the error, realign exactly to center and repeat the rotations and adjustment.
#5 Blackmyst
Blackmyst
Posted 20 June 2025 - 06:57 AM
You're correct - probably not accurate enough.
A false star is a good idea, need to see if I have enough adjustment on my wedge and clearance over the observatory wall - failing that a terrestrial target thats far away...
first step though, is size - I know its not a 1/8 (was able to source), but smaller is proving elusive this side.
#6 michael8554
michael8554
  • Loc: Wiltshire UK
Posted 21 June 2025 - 04:02 AM
On a LX200GPS the long screws that hold the bottom plate onto the mount are the correct Imperial size for that mounts Ortho adjustment.
If you have measured 3/32" that's probably the correct size.
  • Skywatchr likes this
#7 Blackmyst
Blackmyst
Posted 21 June 2025 - 12:20 PM
tx Michael, let me try source.
#8 bdoyle
bdoyle
  • Loc: Silver Springs, Nevada
Posted 24 June 2025 - 11:55 AM
The small screws are 4-40. I have used them to set optical tube in other that original mounts.
#9 Blackmyst
Blackmyst
Posted 27 June 2025 - 06:23 AM
tx, I was able to source 4-40 locally
