I had my 12" SCT out for the first time the other night.
When I went to break it down the next morning I noticed I had forgotten to turn the heat strip up and the entire front glass is covered in dew and my subframes were crap. I had put the dew shield on and had plugged my heater strip into the wrong heater outlet and I did not have that channel turned up. It was set on about 1/4 power but apparently that was not enough to keep the glass clear.
This got me to thinking as to how much heat will I need to apply to the heat strip to keep the glass clear on a 12" SCT?
I have a Pegsus power box that I can use to control the strip and I also have the manual tuner that you just turn the dial up, which is what I had on at the time. There is a lot of surface area and maybe just turning the dial up to 100% will do the trick but I want to make sure that whatever I do it gets rid of the dew. I live in high humidity so everything gets wet at night.
I would prefer to use the Pegasus but not sure if that will do the job.
Has anyone used the Pegasus auto dew heater function on a large SCT and what was the result?
Any other suggestions?
