Except the ES 8.5mm isn't a great eyepiece either:
spherical aberration none
coma none
astigmatism in field toward edge minimal
field curvature none
distortion type and amount pincushion--moderate
chromatic aberration--axial and lateral minimal
apparent field 82°
eye relief comfortable
light scatter control-in field bright planet reflections from eye to lens and back
light scatter control--outside field extremely poor
SAEP none noticed
CAEP minimal
Tint minimal--slightly warm
Vignetting none
Transmission good
thermal issues none
field stop in focus? average
contrast? excellent in center, average at edge
EOFB none
sharpness on axis good
sharpness 50% point in field good
sharpness edge good
comments Primary problem is unrestrained glare from bright
source outside the field. It causes spikes and glare
in the field in linear spikes, loops, and a general
glow across the entire field. The worst I've seen in
an eyepiece of any brand.
In field, a bright object like a planet or bright star causes a
glow to cover the entire field and I tracked it down
to reflection from the cornea to the eye lens and
back again. This is ghosting but it is not reflections
between elements, though it could be from the
bottom of the eye lens elements. The 8.8mm 82°
was not perfect, but it was a lot better in this regard.
Suggestion is to more effectively baffle the lower
elements in the eyepiece and to blacken any spacers
on both sides of the lowest elements to prevent
the reflections in the field. Fix this problem and the
eyepiece would be significantly better.
Among the 8.5mm, 6.5mm, and 4.5mm 82° ES eyepieces, they get progressively worse as the focal length shortens,
The 8.5mm was the best of the three. However, buy a used 8.8mm first. It's a better eyepiece.
If ES fixed the light scatter problems in the 8.5mm, I would recommend it, because the rest of its characteristics are good.
If never used for Moon, planets, or bright stars, the 8.5mm is OK. As a faint galaxies eyepiece, it would be just fine.
