Asi 585 duo/air over a 533mc and the usual route?
#1
Posted 20 June 2025 - 12:38 PM
What do you all think? Does anyone here have experience with both a 533 and the 585 and if so, how large of a difference does is there? Would the small guiding sensor lead to issues with tight filters in light polluted skies?
https://www.highpoin...mera-and-guider
#2
Posted 20 June 2025 - 12:48 PM
I have a 533 and I’m awaiting delivery next week of a 585 air to use with an Askar V and Carbonstar 150. I have high hopes….
#3
Posted 20 June 2025 - 01:28 PM
You’re right it will struggle with wide field stuff since the sensor is so small.
#4
Posted 20 June 2025 - 02:16 PM
I'd be nervous about having all my eggs in one basket. If any one thig has a faiure...
I was also worried about guiding through narrow band filters but I've been hearing that the duos actually do just fine.
Setting up a mini pc is a bit of a task but once done, you have great flexibility to use any equipment you want.
#5
Posted 20 June 2025 - 02:30 PM
I also have a duo and routinely guide with an optolong ultimate filter. I don’t have to speculate, but I do concede that an all in one has no upgrade path likely. I have the financial ability to accept that, and apart from three asiair plus versions, routinely use an “old” pro.
Edited by Nemo51, 20 June 2025 - 03:25 PM.
#6
Posted 20 June 2025 - 02:44 PM
1300$ a 533mono+filter wheel+full set 1.25" filters + OAG + shipping + import taxes.
Not bad.
Regards
JC
https://www.toupteka...=49834614915384
#7
Posted 20 June 2025 - 02:55 PM
You can attach a separate ZWO guide camera to the 585 Air and it will recognize it.
- drd715 likes this
#8
Posted 20 June 2025 - 04:18 PM
But what happens when the power port fails?
#9
Posted 20 June 2025 - 05:28 PM
I’ve never had that happen on cameras or asiairs and suspect abuse would be the issue.
#10
Posted 21 June 2025 - 12:56 AM
Browsing high point scientific, I noticed a new ZWO duo/air camera with the 585mc. I had been planning to get a 533mc pro along with the usual guide scope and camera and an asiair plus but this camera seems like something to consider. At only 999$, I would be saving hundreds compared to getting a guide scope, camera, the seperate asiair and the 533mc. Nonetheless, the camera seems like it might be too similar to my Sony A7III I've been using to upgrade and the much smaller sensor could fall short in some wider field nebula I'd like to capture (used with an SQA55).
Well, my understanding is that the guiding on the duo seems to work fine with filters on a long focal length 14 edge, so with your Focal length and FOV it shouldn’t be a problem. The smaller 2.9 um pixel size is a slightly better match for sampling with your SQA55. On the flip side the FOV will be smaller with the 585, but your field is already pretty wide so you may not care. You can compare on Astronomy tools. Having said that I would still go for the 533 and separate gear
http://astronomy.too.../field_of_view/
