Welcome to the light side.
There's some good tips/info in the forum FAQ:
https://www.cloudyni...eads-and-links/
The best scope is the one you use most.
Baader AstroSolar film is the best in the world. Period.
You can buy better AstroSolar versions of the S50 Solar Filter for £25:
https://www.firstlig...-with-case.html
I have the AngelEyes solar finder (about £20). It works very well. Any solar finder is an absolute essential - it saves so much time and stress. If you have an observatory with a permanently mounted perfectly polar aligned scope then GOTO will find it. That's assuming the GOTO can take into account atmospheric refraction for the time of day (think straw in a glass and how it bends). Did you know just before sunset the sun has already gone below the horizon? Air refraction can cause "why doesn't my GOTO find the sun/planet" questions. A simple solar finder will help you find it. The clue is in the title.
Best time to view are mornings, before the sun has had chance to heat the air and make it wobble.
That doesn't stop me viewing until 6pm in the summer.
Solar "white light" works well with colour cams and mono cams.
Your planetary cameras will be fine.
Eyepiece "sun filters" should be illegal. Think magnifying glass + sun + setting things on fire, which we all do during our school days. A telescope is a huge magnifying glass. Putting all that focused heat through a $10 piece of black plastic will eventually cause it to rupture. And your eye with it. 1 green bottle hanging on the wall. And if 1 green bottle...
My recommendation would be to get a Baader version of the S50 filter and play with it.
If you get bored quickly then maybe solar isnt for you.
If you feel "I want more!" then AstroSolar on your 8" SCT will be a huge step, both in resolution and annoyance - the bigger the scope the more perfect the seeing needs to be.
I have, on average, poor seeing. But I still have Baader AstroSolar for my C9.25 which blows me away even when things are not great. To stare at the most dangerous thing in our solar system with complete safety is just a ton of fun.
Best, Ed.
