10" F/7.7 Harmer-Wynne Cassegrain build using off the shelf components
3 replies to this topic
#1 Etendue645
Etendue645
  • Loc: Tulsa, OK
Posted 21 June 2025 - 09:49 AM
This post is to document and hopefully gather some input on a 10" F/7.7 Harmer Wynne Cassegrain design that I plan to build. For the past few years, Rajesh (RajG) and I have been discussing this idea privately, and I’m now considering moving forward with it. The project involves creating a Harmer Wynne design using off-the-shelf components, specifically a GSO 10" F/4 parabolic mirror and commercially available lenses for the corrector.
Past Experience and Motivation
Why build a Harmer Wynne when I already own a 12.5" F/8 Starizona Hyperion (which is also a Harmer Wynne design)? The answer is simple: for the spirit of ATMing and to pursue a design that has always intrigued me. While my 12.5" F/8 is an excellent optical system, building a smaller, custom version with off-the-shelf components is a challenge that excites me.
Six years ago, I started a similar project to build a 14.5" Harmer Wynne, but I eventually abandoned it due to the challenges of making the corrector lenses. While I got far with the secondary mirror, mirror cell design, and baffle assembly, I ended up converting the project to a Newtonian setup with a 3" Paracorr. I always wished I had completed the Harmer Wynne version, and I’d like to take a moment to personally thank Mike Jones for his help with the optical design and optimization. I feel a bit ashamed for abandoning the project.
With Rajesh’s help and my renewed enthusiasm, I’m revisiting the Harmer Wynne design, this time with the 10" F/4 parabolic mirror I already have on hand and using OTS lens for the corrector elements.
The Harmer Wynne Design: Overview
The Harmer Wynne design is a unique and specialized Cassegrain configuration that features:
  •     Parabolic primary mirror
  •     Spherical secondary mirror
  •     Two corrector lenses in the baffle assembly
This design is especially suited for astrophotography, offering a wide corrected field of view (FOV). The spherical secondary mirror simplifies collimation significantly compared to traditional RC or Classical Cassegrains. While there will be some challenges in collimating and centering the lenses within the baffle, I think these issues are manageable and will address them when the time comes.
Optical Design and Corrector Lenses
Here is the optical design made by Rajesh:
The heart of this project revolves around the corrector lens assembly. I reached out to Ross Optical for a quote on the lenses I’ll need for the corrector, specifically:
  •     L-PCC118 (Plano-Concave)
  •     L-PCX358 (Plano-Convex)
They offered both lenses with broadband anti-reflective coatings (400-700nm) for a total of approximately $650. This price is reasonable when compared to the cost of a high-quality coma corrector, and I’m happy with the balance of cost and expected performance. Of course, I’ll also need to fabricate the lens cell and baffle assembly, but I’m committed to this project in the spirit of ATMing and building an advanced optical system.
Measuring the Parabolic Mirror Radius of Curvature
Before proceeding with the lens order, I need to obtain precise measurements of the radius of curvature for my 10" F/4 parabolic mirror. I have two methods in mind to achieve this:
  •     Radius bar with knife-edge (KE) reading: A straightforward method to get accurate curvature measurements.
  •     Astrometry and plate solving: Using plate solving, without any correctors in the light path, to determine the curvature.
I’ll choose the method that provides the most reliable results for this mirror.
Making the Secondary Mirror
The secondary mirror will be a 4.5" diameter F/7 convex mirror. The curve is fairly shallow, so it should be relatively easy to fabricate. This time (compared to my previous 14.5" Harmer Wynne project), instead of creating a matching concave test plate and using fringes to measure the figure, I plan to polish the secondary and test it directly in the telescope as an assembly. Any necessary touch-ups will be made to the secondary mirror as a complete optical system.
Challenges and Thoughts
One challenge with this design is the short backfocus distance, which requires a very low-profile focuser. I’ve considered designing and using a secondary mirror focusing system, which could eliminate the need for a traditional focuser. However, I’m uncertain about how changing the primary/corrector lens-to-secondary spacing will impact performance.
Rajesh has suggested using a diagonal mirror behind the corrector lens light path and converting the system to a Nasmyth-style configuration to reach focus. This is an option I’ll explore further as the project develops.
Note on optimization: based on the experience I gained from my 14.5" Harmer Wynne build, I know that the ideal process involves measuring each component after it’s made and then re-optimizing the optical design using the measured surface data. However, since the corrector elements for this project will be purchased, I don’t plan to directly measure these surfaces. Instead, I’ll rely on the manufacturing tolerances provided in the engineering drawings (hopefully this is not a mistake).
For the rest of the system, I’ll do my best to measure the secondary mirror radius, primary mirror radius, mirror distances, and corrector lens placement.  I hope to fine-tune everything to create a fully functioning optical system.
I’m excited to revisit this design and build a unique, custom Harmer Wynne Cassegrain. I’d appreciate any input or feedback on the optical design, challenges, or solutions others may have encountered when building a similar system. Looking forward to sharing more updates as I progress!
Edited by Etendue645, 22 June 2025 - 03:33 AM.
  • PrestonE, none, R Botero and 5 others like this
#2 Tucker512
Tucker512
  • Loc: Arizona
Posted 21 June 2025 - 03:23 PM
I love this idea.  As the designer of the Hyperion at Starizona, I'm glad you like your 12.5" scope, but the number of one-off telescopes I have built just for the sake of ATM and fun is substantial.  I made an 8" f/8 "Baby Hyperion" for a friend a few years ago using stock lenses from Newport.  It is optimized for an APS format field.  I made the primary and secondary and there were no issues with not having the exact radii for the lenses other than the manufacturer's tolerances.  The OTA is all carbon fiber with trusses and a 2" Feathertouch focuser, super lightweight. It's adorable.  Have to see if I can find a picture.  But anyway, this idea is totally doable, especially if you only have to make the secondary.  Should be a fun project!
Scott
  • PrestonE, Etendue645, davidc135 and 1 other like this
#3 Etendue645
Etendue645
  • Loc: Tulsa, OK
Posted 21 June 2025 - 04:15 PM
Thanks Scott! I really appreciate your input and admire the Hyperion design. Such an amazing well built scope. I have the CF tube version and I love it!  It will be fun and interesting embarking on this project, very cool about your 8” baby hyperion design!
What are your thoughts on secondary focusing?
#4 Tucker512
Tucker512
  • Loc: Arizona
Posted 21 June 2025 - 05:58 PM
The mirror spacing is not super critical.  Altering the spacing introduces spherical aberration, but something like a few mm either way is not an issue.  The way we assemble the Hyperion is to put a camera on at the known proper backfocus and then move the secondary mirror until the scope is in focus, then lock the secondary down.  If you set the backfocus and then set your secondary position, it will then only move a fraction of a mm for focusing for temperature change, so the spacing will never be an issue.  But the secondary focuser is more complex because you probably need to build something yourself instead of using a stock product.  But from an optical standpoint it is not any issue.  The 8" f/8 I posted above, for example, remains diffraction limited even if the mirrors are despaced by 5mm, which in turn changes the backfocus by almost an inch!  Easy to get closer than that when you assemble it.
  • tturtle and Etendue645 like this
