Bahtinov Question
#1
Posted 22 June 2025 - 01:23 AM
#2
Posted 22 June 2025 - 01:48 AM
Sounds like your frac Bahtinov mask is not optimal.
I use masks with both with my C8 and 80mm frac (and even smaller camera optics) and they work just fine - granted only with camera.
#3
Posted 22 June 2025 - 01:54 AM
Probably just your Newt being better at collecting light than the smaller refractor.
I use a Bahtinov for focusing (albeit for photography), and notice I need longer exposures on smaller diameter scopes. Unfortunately, this trick won't work since you are (presumably) using it for visual
#4
Posted 22 June 2025 - 02:01 AM
Interesting. So just because it looks like a Bahtinov mask doesn't mean it really is a Bahtinov mask. The one with the thicker border is the one for the frac, the other is the one for the 16".
- starhunter50 likes this
#6
Posted 22 June 2025 - 02:32 AM
#7
Posted 24 June 2025 - 05:52 AM
I used an online generator to create the drawing as SVG then had sone laser-cut in acrylic, worked fine. … and yes more slits are better than fewer slits.
