Saturn with Rhea emerging - 6/21/25
8 replies to this topic
#1 dcaponeii
dcaponeii
  • Loc: Waxahachie, TX
Posted 22 June 2025 - 07:14 AM
So as Cor mentioned in Mitchell's post from earlier we've been working on Wavesharp 3.0 which I've used to process these data from this morning.  Winds were at the limits and the seeing was not as good as yesterday morning but the results are too horrible.  I used the cutbox combined with a larger ROI to handle the winds and edge detection in AS!4 to scrub the frames that still had chopped edges.  These are 8% stacks of 20,000 frames.  180s captures for each stack.
First is the full cutbox.
animated2 align w472h584
Here is a second animation with a reduced ROI and resized to 400px.  It's a bit noisier as I decided to run this with only the Layer 1 denoise.  In both I've used the Median color balance option with: R = 39, G = 34 and B = 27.
animated align w400h429
Clicking on the images will bring them up in the gallery viewer at which point the apng's will animate.
  • davidmcgo, Mike Phillips, sfugardi and 14 others like this
#2 happylimpet
happylimpet
  • Loc: Southampton, UK
Posted 22 June 2025 - 08:36 AM
Amazing. Not sure ive ever seen a moon come out from behind saturn so clearly - like a jupiter result.
Your collimation is pretty way out though, as im sure you realise!
  • dcaponeii likes this
#3 dcaponeii
dcaponeii
Posted 22 June 2025 - 08:45 AM
In the first image yes as Saturn was well below 30 degrees still.  But I'm fairly certain that the flaring on Rhea is the result of the 180s capture times.  It's not a coincidence that it's elongated in exactly the direction of travel.  I set the collimation at 40 degrees and checked for flaring a couple of times between autocapture sequences.  It was as good as yesterday's imaging session.
#4 JMP
JMP
Posted 22 June 2025 - 09:44 AM
Superb! Beautiful work on this!
#5 AdrianoMS
AdrianoMS
  • Loc: Volta Redonda, Brazil
Posted 22 June 2025 - 09:49 AM
Very nice!
#6 KMH
KMH
Posted 22 June 2025 - 03:58 PM
Beautiful result!
Kevin
#7 Tulloch
Tulloch
  • Loc: Melbourne, Australia
Posted 22 June 2025 - 05:45 PM
Great stuff Don!
#8 Kokatha man
Kokatha man
Posted 23 June 2025 - 01:51 AM
<"But I'm fairly certain that the flaring on Rhea is the result of the 180s capture times.  It's not a coincidence that it's elongated in exactly the direction of travel.">
  • happylimpet and dcaponeii like this
#9 dcaponeii
dcaponeii
Posted 23 June 2025 - 01:10 PM
Agreed. I’ve got data showing that as the altitude increased so did the collimation. Guess I’ll need to use the mirror locks. I worry I’m the summer about introducing stresses on the mirror by leaving them engaged.
