Hello,
Can anyone help with connecting the HAZ46 to ASIAIR PLUS
-Thanks
Posted 23 June 2025 - 08:00 AM
Hello,
-Thanks
Posted 23 June 2025 - 09:06 AM
The specs say it has USB via the HC. This normally means you need the HC plugged in, and you'd connect the AIR to the HC with a USB cable.
Posted 23 June 2025 - 09:40 AM
OMG, Makes sense smh
-Thanks, I will try that for sure......
Posted 23 June 2025 - 10:07 AM
This is the more traditional way of doing it. Manufacturers are starting to provide a USB port directly on some newer mounts. I'm sure it depends in part on the target audience and intended control scheme - direct or through the manufacturer's own control s/w, which might require the HC to function.
Edited by scanner97, 23 June 2025 - 10:09 AM.
![]() Cloudy Nights LLC Cloudy Nights Sponsor: Astronomics |
