It's been two months since I had clear skies, so I was delighted to have a clear evening this past weekend. I've never imaged M16 before, but I have seen some very colorful images from others, so decided to try to capture it with a dual narrowband filter. This is four hours of data. I found it very challenging to try to bring out any color other than the Ha in the stacked image. Tried many different pixel math combinations I found online, but I ended up going with strict HOO: R:100% Ha, G:100% Oiii, B:100% Oiii.
The resulting image still didn't have much color beyond the red in an autostretch, but after some initial GHS stretches, I did an inverse GHS stretch on the red channel to bring it more inline with the blue/green which brought out the blue/green significantly. Then played around with curves in Siril a bit and further GHS stretches. This was the best I could manage bouncing back and forth between Siril and Seti Astro Suite.
Clouds have set in so I'm unlikely to get much more data to add to this. Looking for any suggestions or tips on anything you see here that I could improve upon. I'm wishing the colors were richer or perhaps more saturated. Not sure if that simply requires more data or if there is some processing piece I'm missing. All acquisition/processing details below.
Thanks for looking.
4 hours dual narrowband (Svbony 220 filter)
60s subs @ 100 gain
darks/flats/darkflats applied
Skywatcher HEQ5-Pro
Askar 71F w .75x reducer
ZWO EAF
ASI533MC @ 0C
NINA
Phd2 guiding
Stacked in Siril with HaOIII extract script
BGE of Ha and Oiii images with Graxpert
Combined in Siril pixel math R: Ha, G: Oiii, B: Oiii
SPCC Color calibration
Cosmic Clarity Sharpening/Denoise
StarNet star removal
GHS/Curves in Siril
HDR/Curves adjustment with SetiAstroSuite
Star mask from separate Pixel Math combination using different weighting for green channel
