Platesolving Error with NINA using a Canon R6
Astrophotography DSLR Imaging Software
5 replies to this topic
#1 sandconp
sandconp
  • Loc: Minnesota USA
Posted 23 June 2025 - 11:57 PM
I am using my Canon R6 Mark II for the first time with NINA using a 24-105mm zoom lens.  I have my lens set at 105mm and I am using ASTAP for Platesolving.  I am getting an error message ASTAP - Plate solve failed.  Large FOV, use G05 (v05) database!  Not enough Stars.  I believe I downloaded the ASTAP D50 database and it works fine with my ZWO dedicated astronomy cameras on my telescopes but not with this mirrorless camera.  I guess it makes sense that using my zoom lens at 105mm that I am going to pick up a very large FOV and platesolver needs a database with more stars I guess?  Is ASTAP ok to use with these type of cameras or should I be looking at using Platesolve2 etc?  I am also trying to use the NINA 3 point polar alignment and that also fails with a platesolve failed message probably because of the same problem.
#2 Tapio
Tapio
  • Loc: Tampere, Finland
Posted 24 June 2025 - 01:07 AM
Just load the database for larger fov as suggested and you should be good.
In ASTAP there's auto setting for selecting which database to use.
So you can have several star databases.
#3 sandconp
sandconp
Posted 24 June 2025 - 11:33 PM
I will give that a shot.  I loaded the G05 database with the existing D50 database and I changed the ASTAP setting in stack to 'Auto'
#4 sandconp
sandconp
Posted 28 June 2025 - 01:11 AM
I added  the G05 database and that resolved my problem.  Thank You.
But I now have a new error message during Plate Solving:
2025-06-28T00:00:41.3149|INFO|CameraVM.cs|Capture|737|Starting Exposure - Exposure Time: 3s; Filter: ; Gain: 3200; Offset -1; Binning: 1x1;
2025-06-28T00:00:47.9659|INFO|ImageSolver.cs|Solve|41|Platesolving with parameters: FocalLength: 105 PixelSize: 6.56 SearchRadius: 30 BlindFailoverEnabled: True Regions: 5000 DownSampleFactor: 0 MaxObjects: 500 Reference Coordinates RA: 20:58:49 Dec: 44° 19' 40" Epoch: J2000
2025-06-28T00:00:48.2291|INFO|BaseImageData.cs|SaveToDisk|344|Saved image to C:\Users\c-san\AppData\Local\NINA\PlateSolver\jajtjvln.e3r.fits
2025-06-28T00:00:49.0904|
WARNING|ASTAPSolver.cs|ReadResult|70|ASTAP - Warning inexact scale! Set FOV=13.83d or scale=12.1"/pix or FL=112mm
2025-06-28T00:00:49.0982|INFO|ImageSolver.cs|Solve|54|Platesolve successful: Coordinates: RA: 20:59:12; Dec: 44° 23' 24"; Epoch: J2000
2025-06-28T00:00:49.1013|INFO|CenteringSolver.cs|Center|99|Centering Solver - Scope Position: RA: 20:59:45; Dec: 44° 25' 26"; Epoch: JNOW; Offset: RA: 00:00:00; Dec: 00° 00' 00"; Distance: 00° 00' 00"; Bearing: 00° 00' 00"; Centering Coordinates: RA: 20:59:44; Dec: 44° 25' 26"; Epoch: JNOW; Solved: RA: 21:00:08; Dec: 44° 29' 11"; Epoch: JNOW; Separation RA: -00:00:23; Dec: -00° 03' 45"; Distance: 00° 05' 36"; Bearing: -47° 51' 07"; Threshold: 2
2025-06-28T00:00:50.8369|INFO|TelescopeVM.cs|Sync|800|Syncing scope from RA: 20:59:45; Dec: 44° 25' 26"; Epoch: JNOW to RA: 21:00:08; Dec: 44° 29' 11"; Epoch: JNOW
2025-06-28T00:00:55.8413|INFO|CenteringSolver.cs|Center|132|Slewing to target after sync. Current Position: RA: 21:00:08; Dec: 44° 29' 11"; Epoch: JNOW; Target coordinates: RA: 20:59:44; Dec: 44° 25' 26"; Epoch: JNOW; Offset RA: 00:00:00; Dec: 00° 00' 00"; Distance: 00° 00' 00"; Bearing: 00° 00' 00"
2025-06-28T00:00:55.8433|INFO|TelescopeVM.cs|SlewToCoordinatesAsync|926|Slewing from RA: 21:00:08; Dec: 44° 29' 11"; Epoch: JNOW to RA: 20:59:44; Dec: 44° 25' 26"; Epoch: JNOW - Alt: 50° 45' 54"; Az: 69° 53' 58"
#5 Tapio
Tapio
Posted 28 June 2025 - 01:32 AM
Just warning. Set your fl setting in NINA @ 112mm.
#6 sandconp
sandconp
Posted 28 June 2025 - 01:49 AM
I was thinking about doing that.  Thank You.
Also tagged with one or more of these keywords: Astrophotography, DSLR, Imaging, Software
