Question,
Can you use a heavy-duty leveling base for leveling your tripod?
Just wondering if the telescope will slew and track accurately.....
LB-90B Leveling Base Tripod Head (Amazon)
Advertised to hold up to 55 pounds
See attachment
Posted 24 June 2025 - 11:56 AM
I use a Neewer 3-point base. Seems to work ok, at least for my scopes which are all under 15 pounds.
Edited by jcj380, 24 June 2025 - 11:56 AM.
Posted 25 June 2025 - 08:42 AM
A GEM doesn’t have to be level to slew and track accurately as long as it is accurately polar aligned, though a level mount may make it easier to polar align some mounts. Leveling is more important for alt/az mounts.
Regardless, level is level, whether achieved by adjusting the tripod leg length or using a leveler on top of the tripod.
It appears that the model you listed, the LB-90B, is designed for cameras with a 1/4”-20 stud on top. If your mount needs a 3/8”-16 stud, consider the LB-90R.
![]() Cloudy Nights LLC Cloudy Nights Sponsor: Astronomics |
