Stacking with siril problem
7 replies to this topic
#1 JustAKidWithATelescope
Posted 24 June 2025 - 01:13 PM
Why did my image come out like this? I have 2 hours of data (60-second subs), and I know there are a lot of dust spots, but even then, I think I should get some data. This is of the North American nebula.
I used a Sony 150 - 600mm telephoto lens (I shot it at 250mm)
A Sony a7riii for the camera
The equal55i pro mount
I used guiding as well
Also, the asiair.
Can someone just tell me why I can't get out like this? All I did to process was a background extraction and an auto-stretch to see the data. But nothing else, please. I need help!
#2 rj144
rj144
Posted 24 June 2025 - 01:30 PM
You didn't take flats and have a lot of vignetting.
If the data is in there, an even background (background extraction) can help bring it out.  But, a background extraction can't work with all the vignetting and the signal is getting buried in the background.
#3 JustAKidWithATelescope
Posted 24 June 2025 - 01:35 PM
Yes I do understand that but even other times when I have used flats my images just have not been good. I have never really had a good nebula photo even with flats and other things. Is it possible that I am not taking my images correctly I have been using 800 iso
#4 rj144
rj144
Posted 24 June 2025 - 01:39 PM
First off, you need to all the calibration files to get the most out of your data.  Post a shot with all the calibration files.
Secondly, is your camera modified?  If not, Ha will be very weak and you'll need a LOT of time to capture it typically.  NA nebula isn't very bright.
If you want a test if what you can do pick a brighter nebula like the Lagoon.
#5 JustAKidWithATelescope
Posted 24 June 2025 - 01:42 PM
are there any other nebulas i could capture all of those ones in. the milky way are on the other side of my house which I cant capture from.
#6 rj144
rj144
Posted 24 June 2025 - 01:48 PM
What at one time is on the one side of your house, will be on the other side of your house later or vice versa.
#7 JustAKidWithATelescope
Posted 24 June 2025 - 01:50 PM
OMG I lowk may or may not have mabye just mabye forgot about that but like I defentily did not forget about that. (i for got about that)
Could you please give me a list of some bright nebula that I could capture from there.
#8 rj144
rj144
Posted 24 June 2025 - 01:54 PM
I have no idea what your first sentence says.  Ha.
There are a few, but I would just focus a few nights on the Lagoon and see how you do first.  Try to get your first nebula down before you waste other time on other nebulas.
