Polar Align and Narrowband
Imaging Filters Polar Alignment
9 replies to this topic
#1 SkyRx83
SkyRx83
  • Loc: Maryland, USA
Posted 24 June 2025 - 06:47 PM
If you plan to shoot an emission nebula with an OSC and a narrowband filter is the recommendation to polar align without the filter in place and then add it once aligned and you go to your target?  I'd like to shoot the Lagoon Nebula and this is my equipment for this session:
RedCat 61
AM5N
ASIAir2600 MC Pro
ASIAir Plus
ASI 120mm Guide cam
ZWO 30mm F/4 MiniScope
Optolong L-Quad Enhance filter
  • rlmxracer likes this
#2 rlmxracer
rlmxracer
  • Loc: Central Texas
Posted 24 June 2025 - 06:52 PM
All you need to do is set the centering time to 5 seconds in the mount section of the app. The standard 2 second exposure is too short unless you are under dark skies.
Welcome to CN.
Edited by rlmxracer, 24 June 2025 - 06:53 PM.
#3 SkyRx83
SkyRx83
Posted 24 June 2025 - 06:56 PM
I just updated my ASIAir Plus and it now limits PA exposure times to only 3 seconds.  I found I could not PA at all with the Optolong L-Quad Enhance filter in place.  I spent two hours trying.until I finally figured out it was likely the filter.  Thanks for the welcome to CN!
#4 rlmxracer
rlmxracer
Posted 24 June 2025 - 07:06 PM
How many stars did the plate solving screen say it detected?
#5 DirtyRod
DirtyRod
  • Loc: Arizona
Posted 24 June 2025 - 08:08 PM
Yes. I PA with just an IR-Cut or even no filter and then swap in the filter before kicking off the plan.
The L-Quad is not very restrictive so 3s will probably work with that filter anyway.
Edited by DirtyRod, 24 June 2025 - 08:11 PM.
#6 Alex McConahay
Alex McConahay
  • Loc: Moreno Valley, CA
Posted 24 June 2025 - 08:28 PM
If you can get a good plate solve with a reasonable exposure using the filter, go ahead and do so. Just keep it on through the Polar Alignment procedure.
However, these filters are known to cut down on the amount of light available to the sensor, thus, you need to increase the exposure. If you can, fine. No problem. But if the exposures are taking too long, or you are not getting good plate solves, it will be frustrating.
So, take the filter off, and use the routine to polar align. And replace the filter.
THe plate solver and the polar alignment routine based on it does not care whether there is a filter in front of the sensor or not. YOu get the same polar alignment either way. It does, however, care if it is getting enough light. And that is something that is easy to experiment with.
Alex
#7 rlmxracer
rlmxracer
Posted 24 June 2025 - 08:58 PM
I misspoke earlier and didn’t realize the PA screen no longer allows 5 second exposures. Pretty dumb on ZWO’s part because not everyone has a wheel or drawer set up to easily swap filters.
#8 AnneD
AnneD
  • Loc: Long Island, NY
Posted 24 June 2025 - 10:07 PM
I updated my ASI Air Plus yesterday and tonight I was able to PA with the Optolong Ultimate filter in the filter drawer. I do not recall the exposure time it used and will pay attention to that the next time. It did take me longer to PA tonight, but I figured that might be due to the heat and humidity in the air tonight.
#9 DirtyRod
DirtyRod
  • Loc: Arizona
Posted 24 June 2025 - 10:46 PM
I assume that’s another bug. I’d bump the exposure or go Bin2 until they fix it or just pull the filter.
Edited by DirtyRod, 24 June 2025 - 10:48 PM.
#10 DirtyRod
DirtyRod
  • Loc: Arizona
Posted 25 June 2025 - 01:19 AM
Looks like ZWO is re-releasing 2.3.3 for both IOS and Android until they sort out 2.4x.
Links pinned in the FB forum page.
Also tagged with one or more of these keywords: Imaging, Filters, Polar Alignment
