Thanks everyone!
The ground is compacted decomposed granite in the pic above, and jumping or walking in the area has no impact on viewing. What I noticed was manual slewing to center an object caused a shake when the slew stops. Tapping near the top of the pier causes a similar shake (more so than my heavy duty tripod, but the tripod is not ideal with a long refractor). Obviously a concrete filled pier would be the gold standard here, but that's not portable. I'm just wondering if there is anything I can do improve this setup while remaining portable.
BTW - tapping near the bottom of the pier does nothing, so I don't think sandbags on the legs would have any impact. The issue appears to be vibration of the main tube, which is unfortunately only 0.090" thick.
I should add, I'm planning to mount larger scopes and even some dual scope setups, so while the above may sound like "nit picking", I want to avoid the problem getting worse with larger setups.
I did see a post where someone said they filled their hollow metal pier with expanding foam and it helped, but I can't find it now. Expanding foam is a mess to clean out, so I want to make darn sure it's going to do what I want before going down that path.
Mark
