Anyone who owns this mount, knows that the tripod STINKS. There is no nicer way to say it...
Hollow, light-weight, thin-wall, aluminum is NOT an acceptable material for tripod legs - especially a tripod designed for astronomical observation. For birdwatching or photography, where one must carry around the mount and move it from place to place, then lightweight hollow aluminum might be a good thing. For a telescope used for high power astronomical observing ..... no. No. NO.
Who at Orion thought this was a good idea? Or, who at Orion in charge of buying caved-in when the salesman from the manufacturer offered these legs via conference call while discussing the AstroView mount?
Orion claims this mount can hold a 5" tube. HA! Very unlikely. I have a 4" short tube mounted on it and it shakes terribly whenever I touch the focuser. In fact, my old Towa EQ-2 from the 1980's had better stability. This was surprising to me. Mostly, this was due to the thick wooden legs that came with the Towa. While the Orion has a beefier head, the Towa tripod wins hands down.
Also, there are two varieties of AstroView mount - the "old" where the rings bolt directly to the head (bad), or the "new" which accepts an Orion dovetail bar similar to the SkyView Pro mount (I assume better) ... I have the newer version, but currently lack the dovetail. Bolting the rings to the mount head does not inspire confidence - two very small bolts go through two UNTHREADED holes in the mount head and through the rings and is held in a place with lock washer and a single nut. The entire bolt-washer-nut arrangement looks TERRIBLY UNDERSIZED for the job of holding my 4" tube (less yet a 5" like Orion says!) ... 6 pounds of OTA plus another 2.5 - 3 pounds of accessories, is almost 10 pounds hanging off of two tiny bolts, the type you would expect to see in a child's toy erector set. And it's not so much the weight - the unthreaded holes introduce the possibility of *slop* if either of the nuts comes loose in the slightest degree. All vibration in the mounting system is channeled via those two bolts (the only connection point between the mount head and the OTA) back and forth between OTA/mount/tripod/ground/observer. It's a terrible mounting arrangement, and I am disappointed a major vendor would offer this as a mounting solution for a 5" scope - shame on them. When I focus my scope, I don't want the view bouncing around.
If I sound harsh, it's not for the sake of being harsh. It's because potential buyers should be made aware that this mount is not what Orion markets it to be. It is not acceptable for a 4" short tube, and certainly not acceptable for a 5" tube.
So, now I am wondering - should I try to improve this AstroView mounting system with some custom tweaks, or should I ditch this subpar mount and upgrade (again) to something heavier? The SkyView Pro looks heavier, but I am reluctant to buy another Orion mount after this experience. I'm sure the Atlas is a good mount, but I don't have $800-$1000 to drop on a mount for a $199 OTA. The SkyView just looks like a slightly beefier version of the AstroView. Slightly is not going to cut it in my book.
--> I have a set of custom-made wood (Ash) legs being made for me, and I know these would be a major improvement over the Orion thin/hollow aluminum legs, which BTW, the chincy plastic spreader is worthless as a stabilizer or brace.
--> I'm thinking of reaming out the ring holes in the mount head to accept a much larger bolt and then bolting down a heavy dovetail bar (no lightweight alum) to the head. Then, bolt the rings to that dovetail using heavier bolts.
--> Insert rubber washers between every metal-to-metal joint that can be opened up.
So, am I trying to polish a rust-bucket here, so to speak, or will the above-mentioned tweaks make a noticeable difference? Has anyone else attempted to improve this mount?
(the bubble level on the mount head has a bubble in it that is too large and it renders the level useless)
(the RA circle has slop in it as well - which I had previously read about in a review here on CN)
MikeG
