25x50 finderscope
#1
Posted 01 April 2007 - 11:47 PM
#2
Posted 02 April 2007 - 10:11 AM
I have a similar one on my Meade 4 inch and it's really nothing more than a "classic" 50mm ota with a r&p focuser.
I'd assume a erecting prism with a 20mm or so eyepiece with crosshairs will get you 25x.
Unfortunately a lot of the 50mm scopes like the Tasco are bolted on the side of the ota so some patching would be needed. Unless you get a scope like a Bushnell, Swift that has a cradle like the one pictured. But I've not seen one in white as above.
Jae
#3
Posted 02 April 2007 - 05:39 PM
Bonco
#4
Posted 02 April 2007 - 07:08 PM
I found a 50mm f/12 Sans&Streiffe refractor with a single sided focuser yesterday. Hopefully that will do the trick for the time being.
-JW:
#5
Posted 02 April 2007 - 07:25 PM
Bigger question is do you have a scope like the one above !!! 108mm Yamamoto ???
#7
Posted 02 April 2007 - 07:55 PM
That sounds like quite a telescope. There was a Palomar on Ebay a month or so ago and then it suddenly disappeared. I was watching it and wanted it. The seller never replied when I asked why he removed it.-Ken
#8
Posted 02 April 2007 - 08:02 PM
All the best with your new finder.
Regards Mark
#9
Posted 02 April 2007 - 08:17 PM
Hi, I thought you might like to see a telescope that I have. It is the same as the one in your attachment.
Hi Mark,
Oops, looks like I should read before I post. Looks like you have the Yamamoto to me ...... sweet? Sure would like to see some closeups of the finderscope when you have time. I assume it's the original mount? Do you have the original wooden tripod? Mind me asking where you found it and how long you've owned it?
I have (2) OTA tube rings like the one on your OTA, but no mount or tripod. The optics are great, for what it is. I was told that mine was used as a guidescope in a observatory, as I was trying to track down the rest of the components. I haven't been able to find a single thing about the scopes background and I have search pretty extensively.
-JWW:
#11
Posted 02 April 2007 - 08:46 PM
Bill
#12
Posted 02 April 2007 - 08:50 PM
Sweet sweet yard cannons!
#13
Posted 02 April 2007 - 09:46 PM
Hi, I thought you might like to see a telescope that I have. It is the same as the one in your attachment. The finder is a great little telescope in itself. I replaced the 25mm eyepiece with a 40mm for wide field viewing. The main tube is a magnificent telescope with exceptional performance given its an achromat. The setup packs into a wood box similar to my 102mm and 60mm Unitrons.
Regards Mark
Wow !!
#14
Posted 02 April 2007 - 11:07 PM
The mount is original, but is carried a pier instead of the wood tripod. The pier was supplied with the telescope and also stores in the wood box with the telescope tube. I have adapted a non original RA drive to the mount.
The setup was purchased about 2 years ago from the original owner, a gentleman in New Zealand, and I had it shipped to Australia. The telescope is 26 years old. I have a 76mm FL1400mm (f18.4) telescope marked SYW inside a diamond. Its magnificent. When I came across this 108mm f1600 in New Zealand, and saw the SYW trademark, I jumped to purchase hoping for performance like the 76mm. I was not disappointed.
I have seen the SYW trademark on tubes engraved Palomar (101mm), Satellite (108mm), Skymaster (108mm), and Sport Master (108mm) on my version. The Y in SYW likely relates to Yamamoto manufacturing.
The Cloudy Nights posting at
shows an advertisement with my pier mounted arrangement. Hope that long link works? Really Long Link
#15
Posted 02 April 2007 - 11:17 PM
All the SYW telescopes that I have come across (60mm up to 108mm) have the same type of machining on the focuser knobs. The larger aperture telescopes have larger diameter knobs but of the same shape. Main tube focuser engraving is below.
Thats great set of Newtonian tubes in the background of one of your previous photos!
Regards Mark
#16
Posted 03 April 2007 - 06:19 AM
Don Wyman
Moderator
#17
Posted 03 April 2007 - 08:23 AM
Regards Mark
#18
Posted 03 April 2007 - 10:15 AM
#19
Posted 03 April 2007 - 09:35 PM
Hi JWW,
All the SYW telescopes that ....
Hello Mark,
My Palomar has the identical trade mark
Thanks for sharing the information.
-JWW:
#22
Posted 03 April 2007 - 09:40 PM
Would it be possible for YOU to trace your finderscope tube rings on a piece of paper and send me the tracing? I have a machine shop in my hope and would like to make something very like the ones on your scope.
-JWW:
#23
Posted 03 April 2007 - 10:39 PM
I can trace the rings for you, but I should explain that to get the tube into the rings, either the focuser assembly or lens cell is unscrewed from the tube, so that the clean tube end will fit through the rings. The tube also has two separate protective rings which slip over the tube to prevent marring of the tube by the collimation screws. I can photograph these also if you wish.
Your new Sans and Streiffe looks excellent.
Mark
#24
Posted 03 April 2007 - 11:06 PM
If you don't feel comfortable taking the rings off the OTA -OR- if it is a hassle, I totally understand. It would just make it easier for me to make them. If a photograph is easier, that's fine too. Some dimenions would be great, well enough so I can build from them, along with the photographs.
Sincerely,
-JWW:
